Outstanding performance starts with reliable, compact hardware technology automatically supported by intuitive routines.
The sleek and compact 40 double sided pages per minute fi-7140 desktop ADF scanner from Fujitsu allows for merging paper document content with digitally born data. Enjoy the introduction of optimum quality from automated document capture and increase the breadth of document management related activities such as invoice and forms processing, archiving and workflow. Flexibly fit this document capture solution to existing and emerging tasks such as current mail delivery methods or addressing regulatory concerns.
Outstanding paper feeding delivers reliable batch scanning regardless of the document condition
These scanners allow the user to scan a wide variety of paper thicknesses (27 to 413 g/m2), as well as plastic cards with the same feeding mechanism inherited from high-end models. In addition, Paper Protection constantly checks along the whole document length during scanning and automatically stops paper feeding when error occurs to avoid any damage to the document. All in all these deliver the reliable scanning experience expected from Fujitsu. -
Reliable Skew Reducer even when scanning a mixed size batch
The fi-7140 automatically detects the document size when scanning a mixed size batch. Furthermore, it is equipped with Skew Reducer to detect the alignment of scanned documents and correct paper skews to minimize missing the edge of the scanned image. Users can rest assured that the result will be good even when scanning documents that are not aligned correctly. -
Compact design for fast scanning right at your desk
The fi-7140 is a compact model that can be placed on the desk, whether for overthe- counter service or for operations in office. It scans at a speed of 40 ppm (A4, color, 200/300 dpi). Simply press the scan button and it will start scanning within a second. Scanning with the fi-7140 will not keep you, or your customers, waiting. -
Automatically creates the most suitable high quality image data for OCR process
The PaperSteam IP scanner driver, which supports TWAIN/ISIS, saves the inconvenience of fine adjusting the settings for the OCR process. It automatically converts the images into exceptionally clean images, accelerating OCR even when scanning wrinkled or soiled documents or documents with a background pattern.
- Fujitsu fi-7140 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- White LED array
- Max Supported Document Size
- 216 x 355.6 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 40 ppm (mono) / 40 ppm (colour)
- Max Document Size
- 216 mm x 5588 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 80 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04
- 30 cm x 17 cm x 16.3 cm
- 4.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 355.6 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- White LED array
- Max Document Scan Speed B/W
- 40 ppm
- Max Document Scan Speed Colour
- 40 ppm
- Scanner Speed Details
- 40 ppm - colour - 200 dpi , 40 ppm - colour - 300 dpi , 40 ppm - greyscale - 200 dpi , 40 ppm - greyscale - 300 dpi , 40 ppm - black & white - 200 dpi , 40 ppm - black & white - 300 dpi , 80 ipm - duplex - colour - 200 dpi , 80 ipm - duplex - colour - 300 dpi , 80 ipm - duplex - greyscale - 200 dpi , 80 ipm - duplex - greyscale - 300 dpi , 80 ipm - duplex - black & white - 200 dpi , 80 ipm - duplex - black & white - 300 dpi
- Scanner Features
- Color Dropout, Dynamic Threshold, Error Diffusion, automatic colour detection, automatic page size detection, Simplified DTC, Advanced DTC, Multi-Image Output, Punch Hole Removal, Deskew, Blank Page Detection
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 5588 mm
- Supported Document Size Details
- ADF - up to 216 x 355.6 mm , Long document - up to 216 x 5588 mm
- Automatic
- 80 sheets
- Interfaces Details
- USB 2.0 - Type B
- RoHS
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 36 Watt
- Software Included
- ScanSnap Manager, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 30 cm
- 17 cm
- 16.3 cm
- 4.2 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
Fujitsu 5x Carrier Sheets for ScanSnap | In Stock | £35.81 |
Fujitsu Extends Warranty From 1 Year to 3 Year For WorkGroup Scanners - Inc Replacement and Shipping | In Stock | £80.57 |
Fujitsu Extends Warranty to 3 Year for Workgroup Scanners - 8hrs On-Site + 8hrs Fix | In Stock | £265.57 |
Fujitsu Scanner Consumable Kit: 3670-400K | In Stock | £69.62 |
