Fujitsu fi-7030 Document Scanner
Quicklinx: C7W8WS00 Mfr#: PA03750-B001
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 355.6 mm
Interface: USB 2.0
Compatibility: PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£398.45 ex VAT
£478.14 inc VAT
The fi-7030 is the ideal entry point to professional information capture. It is equipped with PaperStream Capture Version 1.5 that offers a new ergonomic, touch compatible user interface which improves efficiency and interactions across the entire enterprise capture process. The fi-7030 is based on PFU's proven superior image quality technology, combined with improved image processing and capture software, offering everything that users need to start their digital transformation journey.
The fi-7030 captures A4 documents at a speed of 27 double sided sheets per minute (portrait, color, 300 dpi) and can comfortably process mixed batches that can also include embossed cards, long paper scanning of up to 5 meters through the 50 page ADF is also possible as well as A3 documents utilizing an optional carrier sheet.
The scanner additionally makes use of an ultrasonic sensor that accurately detects multifeed errors where two or more sheets are fed through the scanner at once plus intelligent multifeed function that is designed for documents that intentionally feature paper attachments of defined sizes or locations such as sticky notes or photos. The scanner can automatically recognize the location of the attachment and will then exclude that zone from triggering alert conditions.
Should you be scanning mixed batches of differing thicknesses of documents then the "skew reducer" eliminates the risk of physical skew being carried over from one sheet in a mixed batch to the next ensuring that each document is captured with the utmost precision and simplicity. Multi-segmented pick rollers that rotate independently ensure that if a document goes through skewed then this will not affect the alignment of the next document.
The fi-7030 comes with Scanner Central Admin tools that includes functions that system administrators can use to manage the installation and operation of multiple scanners, monitor operating status and update drivers and software from one location. This ability dramatically reduces the cost and work that goes into setting up, operating and maintaining many scanners in an organization and also in expanding the scanner network to multiple locations.
The fi-7030 comes bundled with PaperStream IP, an integrated scanner driver and image enhancement module that is built on TWAIN/ISIS standards offering user friendly operability, intuitive high quality image creation and real time processing that will benefit post scan routines like OCR. PaperStream Capture 1.5 introduces detailed scanning routine information next to related profile pictograms, facilitating the capture process and allowing users to choose between fully transparent in-depth details for experts, or simplified easy processing for general users. A new "browse view" functionality, which displays both thumbnails and previews on one screen, enables the user to confirm scanned images during scanning. This saves time when users validate, classify and verify data. Other highlights include the display of batch jobs in process for more transparency and an on-the-fly batch release process. Once users have scanned a batch they can verify the data, alternate orders, collect documents in a joint file, index and automatically release to local or distant repositories, feed workflows, business applications or ECM systems.
  • Compact design allowing it to be placed anywhere
    Its noticeable compact size with a sophisticated design suits various environments. The scanner fits in small spaces even smaller than spaces that are A4 in size on a desk.
  • Fast processing performance
    The fi-7030 scans at a speed of 27 ppm / 54 ipm (A4, portrait, color, 200 / 300 dpi). The scanner will not make you or your customers wait with a quick startup time of half a second.
  • Accurate mixed batch scanning for different types of documents
    The Skew Reducer prevents the following documents from being skewed when the preceding document is skewed, thus preventing the image from being incomplete with missing parts even in the case of a batch scan with various types of documents. This also reduces the burden of re-scanning.
  • Automatically creates optimal suited image quality without hassle
    The PaperStream IP scanner driver, which supports TWAIN / ISIS, avoids the inconvenience of fine adjustments to the settings for OCR processes. It automatically converts the images into exceptionally clean images, accelerating OCR even when scanning wrinkled or soiled documents, or documents with a background pattern.
Fujitsu fi-7030 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Light Source
RGB LED array
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
27 ppm (mono) / 27 ppm (colour)
Max Document Size
216 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, embossed card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
AC 120/230 V
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04, Microsoft Windows Server 2016 (64-bit)
29 cm x 14.6 cm x 13 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 355.6 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Dual CCD
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
27 ppm
Max Document Scan Speed Colour
27 ppm
Scanner Speed Details
27 ppm - black & white - A4 - 200 dpi , 27 ppm - greyscale - A4 - 200 dpi , 27 ppm - colour - A4 - 200 dpi , 27 ppm - black & white - A4 - 300 dpi , 27 ppm - greyscale - A4 - 300 dpi , 27 ppm - colour - A4 - 300 dpi , 54 ipm - duplex - black & white - A4 - 200 dpi , 54 ipm - duplex - greyscale - A4 - 200 dpi , 54 ipm - duplex - colour - A4 - 200 dpi , 54 ipm - duplex - black & white - A4 - 300 dpi , 54 ipm - duplex - greyscale - A4 - 300 dpi , 54 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
Multi Color Dropout, Image Emphasis, Long Paper Mode, Dynamic Threshold, Error Diffusion, Ultrasonic multifeed sensor, automatic colour detection, Dither, Simplified DTC, Advanced DTC, Multi-Image Output, image merge, Deskew, Blank Page Detection
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 5588 mm
Automatic
50 sheets
Interfaces Details
USB 2.0 - Type B
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
AC 120/230 V
Power Consumption Operational (Standby)
17 Watt
Power Consumption Stand by
0.15 Watt
Power Consumption Sleep
1.1 Watt
Software Included
Drivers & Utilities, ScanSnap Manager, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
29 cm
14.6 cm
13 cm
2.9 kg
5 °C
35 °C
20 - 80% (non-condensing)
C7W8 Fujitsu 5x Carrier Sheets for ScanSnap In Stock £38.09
C7W8 Fujitsu Extends Warranty From 1 Year to 3 Year For WorkGroup Scanners - Inc Replacement and Shipping In Stock £80.57
C7W8 Fujitsu Extends Warranty to 3 Year for Workgroup Scanners - 8hrs On-Site + 8hrs Fix In Stock £265.57
Interface: USB 2.0
Compatibility: PC
Brand: Fujitsu
