Fujitsu fi-65F A6 Small Format Flatbed Scanner
Quicklinx: C38VWS00 Mfr#: PA03595-B001
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: A6 (105 x 148 mm)
Interface: USB 2.0
Compatibility: PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£217.09 ex VAT
£260.50 inc VAT
The compact, lightweight fi-65F scanner is ideal for busy office and retail environments. It quickly scans important, small documents like passports, IDs, prescriptions, driving licences, customer and medical cards and photographs, and seamlessly integrates with virtually any line of business application (LoB).
  • Ultra compact and fast
    The fi-65F has an impressively small footprint of only 145 x 234 mm, making it ideally suited for even the smallest desktop, reception, check-in desk or cashier booth. It can even be built into the counter-top. The device features High Speed USB 2.0 connectivity, outstanding performance and easy installation. The scanner can be powered through a second USB port on the computer - it can be used easily even in mobile environments where an AC power supply is unavailable. The fi-65F is able to scan A6 sized document in one second. Furthermore, only 0.5 seconds are needed to start scanning. Rapid start-up means customers will not have to wait at the counter.
  • No time, no cover, no problem
    The Fujitsu fi-65F increases user productivity with fast, one-second image capture (at 200 dpi) and coverless scanning. When full detail is needed, the Fujitsu fi-65F delivers clean, crisp scans up to 148 x 105 mm - in color, grayscale or monochrome - with true, 600 dpi optical resolution. Color scans take just 1.7 seconds at 200 dpi. Coverless scanning eliminates the repetitive task of opening and closing the cover before and after each scan. Simply place documents on the flatbed, press the Scan button and scan! Auto-cropping functions optimize the scan size, which helps to conserve storage resources, and auto deskew orientates the scanned image to the correct orientation regardless of how the original is placed on the flatbed.
Fujitsu fi-65F - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
A6 (105 x 148 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels)
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Size
105 mm x 148 mm
Document Feeder Type
Manual
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
14.5 cm x 23.4 cm x 4 cm
900 g
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
A6 (105 x 148 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
Bulb / Light Source Type
RGB LED array
Scanner Speed Details
1.7 sec/scan - portrait colour (AC powered) - 200 dpi , 1 sec/scan - portrait greyscale (AC powered) - A6 - 200 dpi , 1 sec/scan - portrait B&W (AC powered) - A6 - 200 dpi , 1 sec/scan - portrait greyscale (AC powered) - A6 - 300 dpi , 1 sec/scan - portrait B&W (AC powered) - A6 - 300 dpi , 2 sec/scan - portrait colour (USB bus powered) - 200 dpi , 2 sec/scan - portrait greyscale (USB bus powered) - A6 - 200 dpi , 2 sec/scan - portrait B&W (USB bus powered) - A6 - 200 dpi , 2 sec/scan - portrait greyscale (USB bus powered) - A6 - 300 dpi , 2 sec/scan - portrait B&W (USB bus powered) - A6 - 300 dpi
Scanner Features
Powered by USB port
TWAIN, ISIS
Media Handling
Max Document Size
105 mm x 148 mm
Manual
USB 2.0 - Type B
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
8 Watt (2 Watt)
Software Included
Software Operation Panel, PaperStream IP, PaperStream Capture
14.5 cm
23.4 cm
4 cm
900 g
5 °C
35 °C
20 - 80% (non-condensing)
C38V Fujitsu Extends Warranty From 1 Year to 3 Year For Passport Scanners - Inc Replacement and Shipping In Stock £58.19
Interface: USB 2.0
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: 150 - 300
