The compact, lightweight fi-65F scanner is ideal for busy office and retail environments. It quickly scans important, small documents like passports, IDs, prescriptions, driving licences, customer and medical cards and photographs, and seamlessly integrates with virtually any line of business application (LoB).
Ultra compact and fast
The fi-65F has an impressively small footprint of only 145 x 234 mm, making it ideally suited for even the smallest desktop, reception, check-in desk or cashier booth. It can even be built into the counter-top. The device features High Speed USB 2.0 connectivity, outstanding performance and easy installation. The scanner can be powered through a second USB port on the computer - it can be used easily even in mobile environments where an AC power supply is unavailable. The fi-65F is able to scan A6 sized document in one second. Furthermore, only 0.5 seconds are needed to start scanning. Rapid start-up means customers will not have to wait at the counter. -
No time, no cover, no problem
The Fujitsu fi-65F increases user productivity with fast, one-second image capture (at 200 dpi) and coverless scanning. When full detail is needed, the Fujitsu fi-65F delivers clean, crisp scans up to 148 x 105 mm - in color, grayscale or monochrome - with true, 600 dpi optical resolution. Color scans take just 1.7 seconds at 200 dpi. Coverless scanning eliminates the repetitive task of opening and closing the cover before and after each scan. Simply place documents on the flatbed, press the Scan button and scan! Auto-cropping functions optimize the scan size, which helps to conserve storage resources, and auto deskew orientates the scanned image to the correct orientation regardless of how the original is placed on the flatbed.
- Fujitsu fi-65F - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scan Element Type
- Contact Image Sensor (CIS)
- Light Source
- RGB LED array
- Max Supported Document Size
- A6 (105 x 148 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels)
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Size
- 105 mm x 148 mm
- Document Feeder Type
- Manual
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
- 14.5 cm x 23.4 cm x 4 cm
- 900 g
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- A6 (105 x 148 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Element Type
- Bulb / Light Source Type
- RGB LED array
- Scanner Speed Details
- 1.7 sec/scan - portrait colour (AC powered) - 200 dpi , 1 sec/scan - portrait greyscale (AC powered) - A6 - 200 dpi , 1 sec/scan - portrait B&W (AC powered) - A6 - 200 dpi , 1 sec/scan - portrait greyscale (AC powered) - A6 - 300 dpi , 1 sec/scan - portrait B&W (AC powered) - A6 - 300 dpi , 2 sec/scan - portrait colour (USB bus powered) - 200 dpi , 2 sec/scan - portrait greyscale (USB bus powered) - A6 - 200 dpi , 2 sec/scan - portrait B&W (USB bus powered) - A6 - 200 dpi , 2 sec/scan - portrait greyscale (USB bus powered) - A6 - 300 dpi , 2 sec/scan - portrait B&W (USB bus powered) - A6 - 300 dpi
- Scanner Features
- Powered by USB port
- TWAIN, ISIS
Media Handling
- Max Document Size
- 105 mm x 148 mm
- Manual
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 8 Watt (2 Watt)
- Software Included
- Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 14.5 cm
- 23.4 cm
- 4 cm
- 900 g
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
