For the paper-intensive back-office, the Fujitsu fi-6400 scanner digitizes tens of thousands of documents a day. With proven feed mechanics and high-quality image cleanup, the fi-6400 sustains a spectacular throughput, providing businesses with an exceptional ROI. As promised, Fujitsu has delivered a trusted production scanner in a quiet and compact space. To boost the efficiency of large volume scanning at centralized operations, up to 500 sheets can be loaded in the hopper at a time. Together with an impressive scanning speed of 100 ppm (color, A4 size, simplex, 200/300 dpi, landscape), maximum productivity can be achieved. The fi-6400 is capable of digitizing a variety of document types used in many scenarios from ultra-thin receipts to thick documents (20-209 g/m²). In addition, this scanner is equipped with a reliable "paper protection functions" to minimize the risk of documents being damaged even during high speed scanning. The Fujitsu fi-6400 scanner empowers scanner operators to provide efficient centralized batch scanning. The included suite of PaperStream IP, PaperStream Capture and Scanner Central Admin provides users with a powerful, efficient and easy-to-use image enhancement solution to get organizations up and scanning quickly and easily.
PaperStream IP - Automatically creates high quality images without manual adjustments - The scanner driver PaperStream IP, which provides TWAIN/ISIS support, automatically converts documents into exceptionally clean images, improves OCR even when scanning wrinkled/soiled documents or documents with backgrounds and eliminates the hassle of fine tuning scanner settings.
PaperStream Capture - Batch scanning, validate and confirm the document content - PaperStream Capture is an application for scanning and managing scanned images from Fujitsu's fi Series scanners. Adjusting scanning settings and performing batch scanning, are accomplished easily with PaperStream Capture's user-friendly interface. With the seamless linkage to the PaperStream IP driver, high quality image processing and batch scanning are performed simultaneously. With just a few easy settings, PaperStream Capture automates sorting and saving of scanned documents. The "Automatic Image Quality Checker" automatically highlights folded and damaged documents allowing effortless validation of scanned images.
Scanner Central Admin - Efficiently manage multiple scanners - Using the bundled Scanner Central Admin application, up to 1,000 scanners can be managed from one central location. In addition, the usage status is traced, so periodic replacement of consumables can be performed smoothly.
Large volume hopper and high speed scanning
To boost the efficiency of large volume scanning at centralized operation, up to 500 sheets can be loaded to the hopper at a time. Together with the blazing scanning speed of 100 ppm, maximum productivity can be achieved. -
Advanced feeding mechanism
The fi-6400 is capable of digitizing a variety of document types used in every scenario from ultra-thin receipts to thick document. In addition, this scanner is equipped with reliable paper protection functions to minimize the risk of documents being damaged even during the high speed scanning. -
Remarkable small design
Having a front loading feeding mechanism and low height compact design, the fi-6400 allows operators to perform scanning tasks while sitting at the desk. The scanner is designed to minimize the device's height to allow user to load and remove scanned documents with ease. These greatly reduce the stress of operator who tends to operate for long hours. -
Even when installing several scanners, performing the same adjustments to every scanner is unnecessary. Using the bundled Scanner Central Admin, up to 1000 scanners can be managed from one location. In addition, the usage status is traced, so periodic replacement of consumables can be planned and performed smoothly. -
Automatic stacker
Automatic Stacker ensures all your scanned documents tacked neatly and tidily. -
Intelligent multifeed function
The acclaimed intelligent multifeed function simplifies pre-scanning preparation and improves efficiency by ignoring documents that tend to trigger false multifeed alerts, such as documents with intentionally attached photos and sticky notes.
- Fujitsu fi-6400 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- White LED array
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 100 ppm (mono) / 100 ppm (colour)
- Max Document Size
- 297 mm x 420 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 500 sheets
- Duty Cycle
- 40000 scans per day
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
- 46 cm x 43 cm x 31 cm
- 32 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single/duplex pass
- Dual CCD
- Bulb / Light Source Type
- White LED array
- Max Document Scan Speed B/W
- 100 ppm
- Max Document Scan Speed Colour
- 100 ppm
- Duty Cycle
- Scanner Speed Details
- 100 ppm - landscape - A4 - 200 dpi , 100 ppm - landscape - A4 - 300 dpi , 200 ipm - duplex - landscape - A4 - 200 dpi , 200 ipm - duplex - landscape - A4 - 300 dpi , 85 ppm - portrait - A4 - 200 dpi , 85 ppm - portrait - A4 - 300 dpi , 170 ipm - duplex - portrait - A4 - 200 dpi , 170 ipm - duplex - portrait - A4 - 300 dpi
- Scanner Features
- Color Dropout, Ultrasonic Double Feed Detection, Intelligent Multi-Feed Function (iMFF), Paper Protection Function, Image Emphasis, Automatic Image Orientation, Error Diffusion, automatic colour detection, automatic page size detection, upper lower separation, blank page skipping, Dither, Simplified DTC, Advanced DTC, Multi-Image Output, built-in LCD screen, Remove Background, Deskew, Long Document Scanning, Background Color Switching
- TWAIN, ISIS
Media Handling
- Max Document Size
- 297 mm x 420 mm
- Plain paper
- Supported Document Size Details
- Long document - up to 297 x 3048 mm
- Automatic
- 500 sheets
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- Directive 2009/125/EC, RoHS 2011/65/EU
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 200 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 3.2 Watt
- Software Included
- Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 46 cm
- 43 cm
- 31 cm
- 32 kg
- Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- 15 °C
- 35 °C
- 20 - 80% (non-condensing)
