Fujitsu fi-6400 Image Scanner (100ppm)
Quicklinx: BV68WS00 Mfr#: PA03575-B401
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A3 (297 x 420 mm)
Interface: USB 2.0
Compatibility: PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Hurry, only 3 left in stock!
£4,374.26 ex VAT
£5,249.11 inc VAT
For the paper-intensive back-office, the Fujitsu fi-6400 scanner digitizes tens of thousands of documents a day. With proven feed mechanics and high-quality image cleanup, the fi-6400 sustains a spectacular throughput, providing businesses with an exceptional ROI. As promised, Fujitsu has delivered a trusted production scanner in a quiet and compact space. To boost the efficiency of large volume scanning at centralized operations, up to 500 sheets can be loaded in the hopper at a time. Together with an impressive scanning speed of 100 ppm (color, A4 size, simplex, 200/300 dpi, landscape), maximum productivity can be achieved. The fi-6400 is capable of digitizing a variety of document types used in many scenarios from ultra-thin receipts to thick documents (20-209 g/m²). In addition, this scanner is equipped with a reliable "paper protection functions" to minimize the risk of documents being damaged even during high speed scanning. The Fujitsu fi-6400 scanner empowers scanner operators to provide efficient centralized batch scanning. The included suite of PaperStream IP, PaperStream Capture and Scanner Central Admin provides users with a powerful, efficient and easy-to-use image enhancement solution to get organizations up and scanning quickly and easily.
PaperStream IP - Automatically creates high quality images without manual adjustments - The scanner driver PaperStream IP, which provides TWAIN/ISIS support, automatically converts documents into exceptionally clean images, improves OCR even when scanning wrinkled/soiled documents or documents with backgrounds and eliminates the hassle of fine tuning scanner settings.
PaperStream Capture - Batch scanning, validate and confirm the document content - PaperStream Capture is an application for scanning and managing scanned images from Fujitsu's fi Series scanners. Adjusting scanning settings and performing batch scanning, are accomplished easily with PaperStream Capture's user-friendly interface. With the seamless linkage to the PaperStream IP driver, high quality image processing and batch scanning are performed simultaneously. With just a few easy settings, PaperStream Capture automates sorting and saving of scanned documents. The "Automatic Image Quality Checker" automatically highlights folded and damaged documents allowing effortless validation of scanned images.
Scanner Central Admin - Efficiently manage multiple scanners - Using the bundled Scanner Central Admin application, up to 1,000 scanners can be managed from one central location. In addition, the usage status is traced, so periodic replacement of consumables can be performed smoothly.
  • Large volume hopper and high speed scanning
    To boost the efficiency of large volume scanning at centralized operation, up to 500 sheets can be loaded to the hopper at a time. Together with the blazing scanning speed of 100 ppm, maximum productivity can be achieved.
  • Advanced feeding mechanism
    The fi-6400 is capable of digitizing a variety of document types used in every scenario from ultra-thin receipts to thick document. In addition, this scanner is equipped with reliable paper protection functions to minimize the risk of documents being damaged even during the high speed scanning.
  • Remarkable small design
    Having a front loading feeding mechanism and low height compact design, the fi-6400 allows operators to perform scanning tasks while sitting at the desk. The scanner is designed to minimize the device's height to allow user to load and remove scanned documents with ease. These greatly reduce the stress of operator who tends to operate for long hours.
  • Efficiently manage multiple scanners
    Even when installing several scanners, performing the same adjustments to every scanner is unnecessary. Using the bundled Scanner Central Admin, up to 1000 scanners can be managed from one location. In addition, the usage status is traced, so periodic replacement of consumables can be planned and performed smoothly.
  • Automatic stacker
    Automatic Stacker ensures all your scanned documents tacked neatly and tidily.
  • Intelligent multifeed function
    The acclaimed intelligent multifeed function simplifies pre-scanning preparation and improves efficiency by ignoring documents that tend to trigger false multifeed alerts, such as documents with intentionally attached photos and sticky notes.
Fujitsu fi-6400 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
White LED array
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
100 ppm (mono) / 100 ppm (colour)
Max Document Size
297 mm x 420 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
500 sheets
Duty Cycle
40000 scans per day
AC 120/230 V
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
46 cm x 43 cm x 31 cm
32 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
100 ppm
Max Document Scan Speed Colour
100 ppm
Duty Cycle
40000 scans per day
Scanner Speed Details
100 ppm - landscape - A4 - 200 dpi , 100 ppm - landscape - A4 - 300 dpi , 200 ipm - duplex - landscape - A4 - 200 dpi , 200 ipm - duplex - landscape - A4 - 300 dpi , 85 ppm - portrait - A4 - 200 dpi , 85 ppm - portrait - A4 - 300 dpi , 170 ipm - duplex - portrait - A4 - 200 dpi , 170 ipm - duplex - portrait - A4 - 300 dpi
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Intelligent Multi-Feed Function (iMFF), Paper Protection Function, Image Emphasis, Automatic Image Orientation, Error Diffusion, automatic colour detection, automatic page size detection, upper lower separation, blank page skipping, Dither, Simplified DTC, Advanced DTC, Multi-Image Output, built-in LCD screen, Remove Background, Deskew, Long Document Scanning, Background Color Switching
TWAIN, ISIS
Media Handling
Max Document Size
297 mm x 420 mm
Plain paper
Supported Document Size Details
Long document - up to 297 x 3048 mm
Automatic
500 sheets
USB 2.0 - Type B
1 x USB cable
Directive 2009/125/EC, RoHS 2011/65/EU
ENERGY STAR Certified
External power adapter
AC 120/230 V
Power Consumption Operational (Standby)
200 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
3.2 Watt
Software Included
Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
46 cm
43 cm
31 cm
32 kg
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
15 °C
35 °C
20 - 80% (non-condensing)
BV68 Fujitsu Print Cartridge In Stock £61.86
BV68 Fujitsu Extends Warranty From 1 Year to 3 Year For Low Volume Production Scanners - Onsite NBD In Stock £2,266.31
BV68 Fujitsu Extends Warranty 3 Years Low Volume Production Scanners - 8+8hrs On-Site 1 x PM In Stock £2,648.27
BV68 Fujitsu Extends Warranty 3 Years Low Volume Prodcution Scanners - 8hrs On-Site 8hrs Fix 2 xPM In Stock £3,610.60
BV68 Fujitsu Extends Warranty 3 Years Low Volume Production Scanners - 8hrs On-Site 8hrs Fix 3 x PM In Stock £4,534.13
Interface: USB 2.0
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: 1500+
