The Fujitsu fi-6110 scanner's small footprint and advanced feature set make it an ideal solution for decentralized scanning environments. With its true, 600-dpi optical resolution and dual- CCD cameras, it captures your documents' finest details in color, grayscale, and monochrome. What's more, it shares much of the advanced technology found in higher-end scanners, including a 50-sheet automatic document feeder (ADF) that accommodates a wide range of document sizes, ultrasonic double-feed detection for greater security, and a Carrier Sheet function for feeding fragile or oversized (A3) documents. Plus at speeds up to 20 ppm (simplex) / 40 ipm (duplex) it quickly and efficiently transforms your paper documents into more manageable digital files.
- Fujitsu fi-6110 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Max Supported Document Size
- Legal (216 x 356 mm)
- Input Type
- Grayscale / Color Depth
- 10-bit grey
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 20 ppm (mono) / 20 ppm (colour)
- Max Document Size
- 216 mm x 3048 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 2000 scans per day
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
- 29.2 cm x 14.3 cm x 13 cm
- 3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth
- 10-bit grey
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Max Document Scan Speed B/W
- 20 ppm
- Max Document Scan Speed Colour
- 20 ppm
- Duty Cycle
- Scanner Speed Details
- 20 ppm - black & white - A4 - 200 dpi , 20 ppm - colour - A4 - 300 dpi , 40 ipm - duplex - black & white - A4 - 200 dpi , 40 ipm - duplex - colour - A4 - 300 dpi
- Scanner Features
- Color Dropout, Image Emphasis, Error Diffusion, Ultrasonic multifeed sensor, automatic colour detection, automatic page size detection, upper lower separation, blank page skipping, Moire Removal, Dither, Simplified DTC, Advanced DTC, Multi-Image Output
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 3048 mm
- Plain paper
- Automatic
- 50 sheets
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 28 Watt (5.36 Watt)
- Software Included
- ScanSnap Manager, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 29.2 cm
- 14.3 cm
- 13 cm
- 3 kg
- 5 °C
- 35 °C
- 20 - 80%
