Fujitsu fi-5950 A3 Duplex Document Scanner with Paperstream
Quicklinx: C38TWS00 Mfr#: PA03450-B561
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A3 (297 x 420 mm)
Interface: SCSI, USB 2.0
Compatibility: PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Hurry, only 2 left in stock!
£10,949.63 ex VAT
£13,139.55 inc VAT
The FUJITSU Image Scanner fi-5950 production scanner is the paper-to-digital highway that minimizes human interaction with dependable pre to post scan automation. Excellent sheet handling functions and reliable paper processing performance support continuous and efficient mixed batch processing. Operators can incorporate the advanced image enhancement functions and experience high speed processing - essential for productive batch scanning. Fujitsu image enhancement, paper processing and automated procedures result in measurable business advantages when used for production and ad hoc image capture and high-volume archiving.
When faced with large daily demands, document capture bureaus and busy departments can respond with streamlined efficiency. At up to 135 (A4 landscape) pages per minute (ppm) or 270 images per minute (ipm) at 300 dpi resolution and an array of powerful image enhancing and paper-feed functions the fi-5950 can shrink the operator's workload before, during and after scanning.
The bundled PaperStream IP driver takes the work out of image cleanup when scanning invoices, ID cards, receipts, forms, or any other day to day paperwork. PaperStream IP automatically improves the image quality, removes unwanted backgrounds, and optimizes your scanned images for optical character recognition. It is fast and easy to use. The latest innovation, Assisted Scan, allows users to replace poor images by visually selecting the image they lack rather than learning driver settings. If driver settings need to be adjusted for rare and difficult documents, a preview function allows scan operators to see their adjustments in real-time without time consuming re-scans. PaperStream IP works with both ISIS and TWAIN applications.
The bundled PaperStream Capture makes advanced capture with Fujitsu scanners easier than before. PaperStream Capture has a streamlined User Interface to reduce training time and increase productivity. Not only has FUJITSU provided users with the most common profiles used by customers - black and white, color, and auto-color - new profiles are easily created or modified through a wizard. FUJITSU has organized the release screen so that batches can easily be suspended or continued. PaperStream Capture is also integrated with PaperStream IP's assisted scanning for visual cleanup of documents. The reading of barcodes and patch codes make batch separation easy, improving document organization.
Fujitsu fi-5950 - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scan Element Type
Dual CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
10-bit grey / 24-bit (16.7 million colours)
Grayscale / Color Depth (External)
8-bit (256 grey levels)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
135 ppm (mono) / 135 ppm (colour)
Max Document Size
305 mm x 3048 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
500 sheets
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
54 cm x 54 cm x 50 cm
50 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0, SCSI
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
Max Document Scan Speed B/W
135 ppm
Max Document Scan Speed Colour
135 ppm
Scanner Speed Details
135 ppm - black & white - A4 , 135 ppm - colour - A4 , 270 ipm - duplex - black & white - A4 , 270 ipm - duplex - colour - A4
Scanner Features
Ultrasonic multifeed sensor
TWAIN, ISIS
Media Handling
Max Document Size
305 mm x 3048 mm
Plain paper
Automatic
500 sheets
Ultra Wide SCSI - HD-68 , USB 2.0 - Type B
1 x USB cable
RoHS
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Internal power supply
54 cm
54 cm
50 cm
50 kg
15 °C
35 °C
20 - 80%
C38T Fujitsu Extends Warranty From 1 Year to 3 Year For Low Volume Production Scanners - Onsite NBD In Stock £2,266.31
C38T Fujitsu Extends Warranty 3 Years Low Volume Production Scanners - 8+8hrs On-Site 1 x PM In Stock £2,648.27
C38T Fujitsu Extends Warranty 3 Years Low Volume Prodcution Scanners - 8hrs On-Site 8hrs Fix 2 xPM In Stock £3,610.60
C38T Fujitsu Extends Warranty 3 Years Low Volume Production Scanners - 8hrs On-Site 8hrs Fix 3 x PM In Stock £4,534.13
Interface: SCSI
Interface: USB 2.0
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: 1500+
