The Fujitsu fi-5530C2 color A3 departmental scanner offers an incredible feature set in a compact package. It features dual color CCDs with true, 600-dpi resolution for capturing subtle details, and uses ultrasonic double-feed detection for reliable, automatic scanning. For simplified connectivity the Fujitsu fi-5530C2 features a dual-interface, including ports for SCSI and USB 2.0 connections. The fi-5530C2 is bundled with PaperStream IP and PaperStream Capture.
- Fujitsu fi-5530C2 - document scanner - desktop - USB 2.0, SCSI
- Document scanner - desktop
- Interface Type
- USB 2.0, SCSI
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth
- 10-bit grey
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 35 ppm (mono) / 35 ppm (colour)
- Max Document Size
- 297 mm x 863 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 100 sheets
- Duty Cycle
- 2500 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
- 39.9 cm x 22.5 cm x 19.3 cm
- 8.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0, SCSI
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth
- 10-bit grey
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single/duplex pass
- CCD
- Max Document Scan Speed B/W
- 35 ppm
- Max Document Scan Speed Colour
- 35 ppm
- Duty Cycle
- Scanner Speed Details
- 35 ppm - black & white , 35 ppm - colour , 70 ipm - duplex - black & white , 70 ipm - duplex - colour
- TWAIN, ISIS
Media Handling
- Max Document Size
- 297 mm x 863 mm
- Plain paper
- Automatic
- 100 sheets
- USB 2.0 - Type B , Ultra SCSI
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 57 Watt (7.5 Watt)
- Software Included
- ScanSnap Manager, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 39.9 cm
- 22.5 cm
- 19.3 cm
- 8.5 kg
- 5 °C
- 35 °C
- 20 - 80%
