Take advantage of PCI Express (PCIe) server slots to enhance network performance with the Intel PRO/1000 PT Server Adapter. The dedicated input/output (I/O) bandwidth of PCIe ensures priority performance - without bus sharing - for Gigabit Ethernet connectivity in Category-5 networks. Additionally, the Intel PRO/1000 PT Server Adapter is designed to provide high performance in multiprocessor systems by efficiently balancing network loads across multiple Central Processing Units (CPUs) when used with Receive-Side Scaling from Microsoft or Scalable I/O on Linux.
The Intel PRO/1000 PT Server Adapter represents the fifth generation of Intel network adapters for Gigabit Ethernet, and features 10/100/1000 Mbps self-configuration for compatibility with mixed speed network devices. For easy installation and management, all Intel PRO Network Connections are supported by Intel PRO Intelligent Install and the new Intel PROSet Utility for Microsoft Device Manager. Intel PROSet simplifies adapter installation and gives you point-and-click power to configure and manage all your Intel PRO Network Connections for connectivity you can count on.
- Intel PRO/1000 PT Server Adapter - network adapter - PCIe - Gigabit Ethernet
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.0a
- Bus Voltage
- 3.3 V
- Ports
- Gigabit Ethernet
- 2.2 cm x 12.9 cm x 12 cm
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- Processor
- Intel 82572GI
- IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), WfM 2.0
- System Requirements
- SCO OpenServer 5, Microsoft Windows 2000, Novell NetWare 5.x, SunSoft Solaris x86 8, Novell NetWare 6.x, Caldera OpenUnix 8, Linux 2.4 or later, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Datacenter Edition, FreeBSD 4.x
- Designed For
- PRIMERGY Econel 100, Econel 100 S2, Econel 230R S1, RX220, RX330 S1, RX600 S4, TX100 S1, TX100 S2, TX150 S5, TX150 S6, TX150 S7, TX200 S3, TX200 S4, TX200 S5, TX200 S6, TX300 S3, TX300 S4, TX300 S5, TX300 S6, TX600 S3
- Network adapter
- Form Factor
- Plug-in card
- PCI Express x1
- PCIe 1.0a
- Bus Voltage
- 3.3 V
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Remote Management Protocol
- SNMP, DMI 2.0
- Status Indicators
- Port transmission speed, link OK
- Full duplex capability, fault tolerance, ACPI support, auto-negotiation, Cisco Fast EtherChannel, load balancing, wake on LAN (WOL), Cisco Gigabit EtherChannel
Processor / Memory
- Processor
- Intel 82572GI
- 1 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Full-height bracket
- FCC Class B certified, UL, VCCI, C-Tick, BSMI, MIC
- OS Required
- 2.2 cm
- 12.9 cm
- 12 cm
- 0 °C
- 55 °C
- Designed For
- Fujitsu PRIMERGY Econel 100, Econel 100 S2, Econel 230R S1, RX220, RX330 S1, RX600 S4, TX100 S1, TX100 S2, TX150 S5, TX150 S6, TX150 S7, TX200 S3, TX200 S4, TX200 S5, TX200 S6, TX300 S3, TX300 S4, TX300 S5, TX300 S6, TX600 S3
