Delivering reliable operation at an affordable price makes ETERNUS DX60 S3 an ideal disk storage system for small and medium-sized IT environments. Management software, included at no extra cost, reduces administration effort and provides functionality to ensure data protection. Flexible support for different network connections and disk types enables choice in cost and performance optimization. Designed for smaller environments it provides remarkable scalability in storage capacity offering good headroom for future growth. The perfect storage solution for consolidation of distributed data and for smaller server virtualization projects.
- Fujitsu ETERNUS DX 60 S3 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Max Supported Capacity
- 144 TB
- Interface
- SAS 6Gb/s
- Maximum LUNs
- 1024
- Installed Devices / Modules Qty
- 24 (max)
- Supported Drives
- SAS-2
- Storage Controller
- RAID (SAS 6Gb/s) - RAID RAID 0, 1, 5, 6, 10, 50
- Hard Drive
- 0 no HDD SAS 6Gb/s - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 48.2 cm x 67 cm x 8.8 cm
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- Supported Devices / Modules Qty
- 24
- Supported Drives
- SAS-2
Storage
- 144 TB
- HDD Array External Interface
- SAS 6Gb/s
- Maximum LUNs
- 1024
Storage Controller
- RAID
- Interface Type
- SAS 6Gb/s
- Cache / Buffer Size (Max)
- 2 GB
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
- No HDD - hot-swap
- Capacity
- 0
- Interface Type
- SAS 6Gb/s
- Expansion Bays
- 24 (total) / 24 (free) x hot-swap - 3.5"
- 1 x Ethernet 1000Base-T (management) , 1 x SAS 6Gb/s
- 92% efficiency power supply, SNMP support
- VCCI, C-Tick, CISPR 22 Class A, GS, EN55024, EN55022 Class A, CB, ICES-003 Class A, FCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FCC CFR47, GOST-R, CSA C22.2 No. 60950-1, Directive 2004/108/EC, Directive 2006/95/EC, VCCI Class A, Directive 2011/65/EC, EAC, CNS 13438
- Power Device
- 2 x internal power supply
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- 48.2 cm
- 67 cm
- 8.8 cm
- Limited warranty - 3 years - on-site
- 10 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 49 dBA
