Your basket is empty
Fujitsu ET DX60 S3 Base 2.5
Quicklinx: BD97WS00 Mfr#: FTS:ET063AU
Delivering reliable operation at an affordable price makes ETERNUS DX60 S3 an ideal disk storage system for small and medium-sized IT environments. Management software, included at no extra cost, reduces administration effort and provides functionality to ensure data protection. Flexible support for different network connections and disk types enables choice in cost and performance optimization. Designed for smaller environments it provides remarkable scalability in storage capacity offering good headroom for future growth. The perfect storage solution for consolidation of distributed data and for smaller server virtualization projects.
Fujitsu ETERNUS DX 60 S3 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
144 TB
SAS 6Gb/s
Maximum LUNs
1024
24 (max)
Supported Drives
SAS-2
Storage Controller
RAID (SAS 6Gb/s) - RAID 0, 1, 5, 6, 10, 50
Hard Drive
0 no HDD SAS 6Gb/s - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
48.2 cm x 67 cm x 8.8 cm
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
Supported Devices / Modules Qty
24
Supported Drives
SAS-2
Storage
144 TB
HDD Array External Interface
SAS 6Gb/s
Maximum LUNs
1024
Storage Controller
RAID
Interface Type
SAS 6Gb/s
Cache / Buffer Size (Max)
2 GB
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
No HDD - hot-swap
0
Interface Type
SAS 6Gb/s
Expansion Bays
24 (total) / 24 (free) x hot-swap - 3.5"
1 x Ethernet 1000Base-T (management) , 1 x SAS 6Gb/s
92% efficiency power supply, SNMP support
VCCI, C-Tick, CISPR 22 Class A, GS, EN55024, EN55022 Class A, CB, ICES-003 Class A, FCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FCC CFR47, GOST-R, CSA C22.2 No. 60950-1, Directive 2004/108/EC, Directive 2006/95/EC, VCCI Class A, Directive 2011/65/EC, EAC, CNS 13438
2 x internal power supply
Max Supported Qty
2
Power Redundancy
48.2 cm
67 cm
8.8 cm
Limited warranty - 3 years - on-site
10 °C
20 - 80% (non-condensing)
Sound Emission
49 dBA
