Fujitsu Esprimo X956/T Core i3-6100T 4GB 500GB Windows 10 Pro
Quicklinx: CS3HWS00 Mfr#: VFY:X956TP23ABGB
Processor Type: Core i3
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 500GB, 500GB
Storage Type: HDD
  • Core i3
£484.11 ex VAT
£580.93 inc VAT
The sophisticated FUJITSU ESPRIMO X956/T has all the advantages of a PC plus a multi-position 23-inch touch display and innovative easy log on features. Achieve significant TCO savings with DeskView and Intel vPro technology and protect confidential data with the latest TPM controller. With the Low Power Active mode it supports a wide range of usage scenarios such as telephony and video conferencing.
  • Human centric
    This PC features a 23-inch widescreen IPS-panel with an adjustable display providing the ideal working position.
  • Stay connected and save power
    Innovative Low Power Active mode and high-efficiency integrated power supply.
  • Multitouch operations
    Excellent ergonomic operations with multitouch screen for the next generation user interface.
Fujitsu ESPRIMO X956/T - all-in-one - Core i3 6100T 3.2 GHz - 4 GB - 500 GB - LED 23"
Personal computer - all-in-one
Region: United Kingdom
1 x Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 3Gb/s - 5400 rpm
Optical Storage
No optical drive
Monitor
23" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Intel HD Graphics 530 Shared Video Memory (UMA)
GigE
OS Provided
55.4 cm x 22.5 cm x 43.3 cm
8.62 kg
Environmental Standards
Blue Angel
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers, touch screen display
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q170 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
LED - IPS
Touchscreen
Yes (multi-touch)
Diagonal Size
23"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Pixel Pitch
0.265 mm
Response Time
14 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
10000000:1
Monitor Features
Anti-glare, High Frame Rate Control (Hi-FRC)
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
High Definition Audio
Ethernet Controller
Intel I219-LM
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 2.5" , 1 (total) / 1 (free) x internal M.2 2280
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2280
1 x audio line-out/headphones , 1 x audio line-in/microphone , 6 x USB 3.0 (4 rear) , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
Power supply
Nominal Voltage
Power Provided
90 Watt
Efficiency
91% at 100% Load, 87% at 20% Load, 90% at 50% Load, 85% at 10% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Adobe Reader, Microsoft Office (Trial), McAfee Multi Access (60 days trial), Windows 10 Pro 64-bit recovery DVD
Blue Angel Compliant
55.4 cm
22.5 cm
43.3 cm
8.62 kg
10 °C
35 °C
5 - 85%
Fujitsu Esprimo X956/T Core i3-6100T 4GB 500GB Windows 10 Pro Bundle deal on Fujitsu Esprimo X956/T Core i3-6100T 4GB 500GB Windows 10 Pro
£583.28
Storage Type: HDD
Processor Model: I3-6100T
Type: Personal computer
Case Style: All-in-one
Optical Storage: None
Brand: Fujitsu
Price Range Ex VAT: 300 - 500
