Fujitsu Esprimo Q957 Core i7-7700T 8GB 256GB SSD Windows 10 Pro
Quicklinx: CS3GWS00 Mfr#: VFY:Q0957P47SPGB
  • Core i7
  • IEEE 802.11n
The Fujitsu ESPRIMO Q957 provides excellent performance, high energy efficiency and manageability. The powerful processor and Intel vPro technology combined with the DeskView manageability suite support professional computing and sophisticated manageability. With its innovative Low Power Active Mode feature you are ready for instant communication in the modern office. Experience a cleaner, quieter workplace with Zero Noise PC function and the small footprint of the Fujitsu ESPRIMO Q957.
  • An elegant PC for the modern office environment
    Easy integration into customers' existing infrastructure.
  • Innovative low power active mode and highly-efficient integrated power-supply
    Be ready for instant communication and significantly reduce your energy bill.
  • Sophisticated system management
    Simple system administration even in complex IT infrastructures.
  • Superb usability
    Efficient working environment due to a tidy desk.
Fujitsu ESPRIMO Q957 - mini PC - Core i7 7700T 2.9 GHz - 8 GB - 256 GB - UK
Personal computer - mini PC
Platform Technology
Intel vPro Technology
Region: United Kingdom
1 x Intel Core i7 (7th Gen) 7700T / 2.9 GHz (3.8 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB - SATA 6Gb/s - M.2 2280 - NVM Express (NVMe)
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 630 Shared Video Memory (UMA)
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.1
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
18.6 cm x 19.1 cm x 5.9 cm
1.6 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - carry-in
Platform Technology
Personal computer
Product Form Factor
Mini PC
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q270
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
SATA 6Gb/s
NVM Express (NVMe)
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x internal 2.5" , 1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x memory , 1 (total) / 0 (free) x M.2 Card - 2280 , 1 (total) / 0 (free) x M.2 Card - 2230
1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 2 x USB 2.0 (2 rear) , 6 x USB 3.1 Gen 1 (2 front, 4 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x DisplayPort , 1 x DVI-D , 1 x serial , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
Power supply
Nominal Voltage
Power Provided
65 Watt
Efficiency
92% at 100% Load, 92% at 50% Load, 90% at 20% Load, 90% at 10% Load
Operating System / Software
OS Provided
Software
Adobe Reader, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect, Windows 10 Pro 64-bit recovery DVD
ENERGY STAR Certified
ENERGY STAR Version
6.1
18.6 cm
19.1 cm
5.9 cm
1.6 kg
10 °C
35 °C
5 - 85%
