The Fujitsu ESPRIMO Q957 provides excellent performance, high energy efficiency and manageability. The powerful processor and Intel vPro technology combined with the DeskView manageability suite support professional computing and sophisticated manageability. With its innovative Low Power Active Mode feature you are ready for instant communication in the modern office. Experience a cleaner, quieter workplace with Zero Noise PC function and the small footprint of the Fujitsu ESPRIMO Q957.
An elegant PC for the modern office environment
Easy integration into customers' existing infrastructure. -
Innovative low power active mode and highly-efficient integrated power-supply
Be ready for instant communication and significantly reduce your energy bill. -
Sophisticated system management
Simple system administration even in complex IT infrastructures. -
Superb usability
Efficient working environment due to a tidy desk.
- Fujitsu ESPRIMO Q957 - mini PC - Core i7 7700T 2.9 GHz - vPro - 8 GB - SSD 256 GB - UK
- Personal computer - mini PC
- Platform Technology
- Intel vPro Platform
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i7 (7th Gen) 7700T / 2.9 GHz (, up to 3.8 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 630 Shared Video Memory (UMA)
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Adobe Reader, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect, Windows 10 Pro 64-bit recovery DVD
- 18.6 cm x 19.1 cm x 5.9 cm
- 1.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - carry-in
- Personal computer
- Product Form Factor
- Mini PC
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q270
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- DVI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB410
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Remote Management Protocol
- DMI, CIM
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x internal 2.5" , 1 (total) / 0 (free) x external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x memory , 1 (total) / 0 (free) x M.2 Card - 2280 , 1 (total) / 0 (free) x M.2 Card - 2230
- 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 2 x USB 2.0 (2 rear) , 6 x USB 3.1 Gen 1 (2 front, 4 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x DisplayPort , 1 x DVI-D , 1 x serial , 1 x LAN (Gigabit Ethernet) - RJ-45
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
- Power supply
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 92% at 100% Load, 92% at 50% Load, 90% at 20% Load, 90% at 10% Load
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 18.6 cm
- 19.1 cm
- 5.9 cm
- 1.6 kg
- 10 °C
- 35 °C
- 5 - 85%
