The FUJITSU ESPRIMO Q956 mini PC provides excellent performance, high energy efficiency and manageability. The Intel Core processor and Intel vPro technology combined with the DeskView manageability suite support professional computing and sophisticated manageability. With its innovative Low Power Active Mode feature you are ready for instant communication in the modern office. Experience a cleaner, quieter workplace with Zero Noise PC function and the small footprint of the FUJITSU ESPRIMO Q956.
- Fujitsu ESPRIMO Q956 - mini PC - Core i7 6700T 2.8 GHz - vPro - 8 GB - SSD 256 GB
- Personal computer - mini PC
- Platform Technology
- Intel vPro Platform
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i7 (6th Gen) 6700T / 2.8 GHz (, up to 3.6 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 530 Shared Video Memory (UMA)
- Audio Output
- 5.1 channel surround
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence
- Software Included
- Adobe Reader, Microsoft Office (Trial), Fujitsu Recovery, DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Windows 7 Professional (32/64 bits) / Windows 10 Pro 64-bit Twin-Pack recovery DVD
- 18.6 cm x 19.1 cm x 5.9 cm
- 1.6 kg
- Manufacturer Selling Program
- Fujitsu Premium Selection
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini PC
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.8 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q170
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- DVI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Mouse
- Mouse Name
- Fujitsu GL9000
- Technology
- Laser
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Remote Management Protocol
- DMI, CIM
- Wake on LAN (WoL), PXE support
- Bays
- 1 internal 2.5" , 1 (total) / 0 (free) x external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 M.2 Card
- 2 x audio line-out/headphones (1 in front) , 1 x audio line-in/microphone (1 in front) , 2 x USB 2.0 (2 rear) , 6 x USB 3.0 (2 front, 4 rear) , 2 x DisplayPort , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x serial
- Theft/Intrusion Protection
- FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
- Power supply
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 92% at 100% Load, 92% at 50% Load, 90% at 20% Load, 90% at 10% Load
Operating System / Software
- OS Provided
- Software
- 18.6 cm
- 19.1 cm
- 5.9 cm
- 1.6 kg
- 10 °C
- 35 °C
- 5 - 85%
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £15.80 |
