The Fujitsu ESPRIMO Q920 delivers excellent performance, high energy efficiency and manageability in a mini PC. An Intel Core processor and Intel vPro technology deliver professional computing and sophisticated manageability. The zero noise functionality eliminates disturbing noise while the small footprint of the Fujitsu ESPRIMO Q920 cleans up your workplace.
Beautify your desk
This PC will attract attention. With its small and stylish design, the Fujitsu ESPRIMO Q920 satisfies a so far unanswered business need: PC becomes fashionable. Though very small in size - about half of a DIN A4 piece of paper, special design, just 1.9 liters of volume and lightweight it is a full-blown PC. -
Get the most energy efficient PC
As energy saving is one of the core components of Fujitsu's approach to the environment, it permanently tries to improve the energy efficiency of the products. The Fujitsu ESPRIMO Q920 is the most energy efficient PC within portfolio taking advantage of the latest energy-saving technology used in desktops. -
Manageability
Maximum system security and manageability are of critical importance to IT managers. With the Intel vPro technology and the integrated Intel Active Management Technology (iAMT), Intel is seeking to improve these levels still further, in the deskbound and notebook sector. The Fujitsu ESPRIMO 920 series supports Intel vPro technology - simple administration made easier. -
Flexibility
Each business has unique, specific requirements to its IT infrastructure. You have the freedom of choice in getting systems which perfectly fit in your specific environment with hardware, software, and add-on and lifecycle management.
- Fujitsu ESPRIMO Q920 - mini PC - Core i5 4590T 2 GHz - vPro - 4 GB - HDD 500 GB
- Personal computer - mini PC - administrator password, system password, hard drive password, USB port control, wake on LAN, Fujitsu EraseDisk
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (4th Gen) 4590T / 2 GHz (, up to 3 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB L3 Cache
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 5400 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- Graphics Controller
- Intel HD Graphics 4600 Shared Video Memory (UMA)
- Audio Output
- Integrated
- Networking
- GigE, Bluetooth, 802.11b/g/n
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro Licence
- Software Included
- Adobe Reader, Fujitsu Recovery, Microsoft Office 2013 (Trial), McAfee Multi Access (60 days trial), Workplace Protect, Windows 7 / Windows 8.1 Pro Twin-Pack recovery DVD
- 18.5 cm x 19.1 cm x 5.87 cm
- 1.6 kg
- Manufacturer Selling Program
- Fujitsu Premium Selection
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini PC
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
- CPU
- Clock Speed
- 2 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel Q87
Cache Memory
- Installed Size
- L3 Cache - 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- MultiMediaCard, SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- VGA, DVI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Integrated
Input Device
- Mouse, keyboard
Mouse
- Mouse Name
- Fujitsu GL9000
- Technology
- Optical
- Interface
- USB
- Scroll
- Integrated
- Ethernet Controller
- Intel I217-LM
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Remote Management Protocol
- DMI 2.0
- Wake on LAN (WoL), PXE support
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Bays
- 1 (total) / 0 (free) x internal 2.5" , 1 (total) / 1 (free) x external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x memory
- 1 x audio line-out/headphones , 1 x audio line-in/microphone , 2 x USB 2.0 , 4 x USB 3.0 (2 front, 2 rear) , 1 x DisplayPort , 1 x DVI-I , 1 x LAN (Gigabit Ethernet)
- Cables Included
- DVI-VGA adapter
- Administrator password, system password, hard drive password, USB port control, wake on LAN, Fujitsu EraseDisk
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- Blue Angel Compliant
- 18.5 cm
- 19.1 cm
- 5.87 cm
- 1.6 kg
- 10 °C
- 35 °C
- 5 - 85%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
