Fujitsu Esprimo Q556 Intel Core i3-6100T 4GB 500GB Windows 10 Professional
Quicklinx: BZQYWS00 Mfr#: VFY:Q0556P733OGB
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
The Fujitsu ESPRIMO Q556, featuring full desktop PC functionality in a stylish and compact mini PC, is a real eye-catcher on your desk. Its advanced processor provides the performance to meet your daily office needs. The Zero Noise PC function ensures silent operation. An integrated efficient power supply reduces your energy bill. With its alternative Low Power Active mode you are ready for instant communication. Its compact interface makes the Fujitsu ESPRIMO Q556 your first choice for locations where space saving is a key.
  • An elegant mini PC for challenging office tasks
    With its eye-catching exclusive design this PC is fully equipped and based on standard desktop technology.
  • Stay connected and save power
    Be ready for instant communication and a significantly reduced energy bill with the alternative Low Power Active mode and highly-efficient integrated power-supply.
  • Superb usability
    Thanks to horizontal or vertical operations you have an efficient working environment.
Fujitsu ESPRIMO Q556 - mini PC - Core i3 6100T 3.2 GHz - 4 GB - HDD 500 GB
Personal computer - mini PC
Region: United Kingdom
Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 530 Shared Video Memory (UMA)
Audio Output
5.1 channel surround
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence
Software Included
Microsoft Office (Trial), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Professional (64-bit)
18.6 cm x 19.1 cm x 5.5 cm
1.6 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Mini PC
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111GN
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" x 1/8H
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card
2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in/microphone (1 in front) , 2 x USB 2.0 , 4 x USB 3.0 (2 front, 2 rear) , 1 x DisplayPort , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x serial
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, GS, WHQL, RoHS, WEEE, cCSAus, China RoHS
Power supply
Power Provided
65 Watt
Efficiency
92% at 100% Load, 92% at 50% Load, 90% at 20% Load, 90% at 10% Load
Operating System / Software
OS Provided
Software
ENERGY STAR Certified
18.6 cm
19.1 cm
5.5 cm
1.6 kg
10 °C
35 °C
5 - 85%
BZQY C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
