Fujitsu Esprimo Q556 Intel Core i3-6100T 4GB 500GB Windows 10 Home
Quicklinx: BZQBWS00 Mfr#: VFY:Q0556P73ACGB
  • Core i3
  • IEEE 802.11n
The Fujitsu ESPRIMO Q556, featuring full desktop PC functionality in a stylish and compact mini PC, is a real eye-catcher on your desk. Its advanced processor provides the performance to meet your daily office needs. The Zero Noise PC function ensures silent operation. An integrated efficient power supply reduces your energy bill. With its alternative Low Power Active mode you are ready for instant communication. Its compact interface makes the Fujitsu ESPRIMO Q556 your first choice for locations where space saving is a key.
  • An elegant mini PC for challenging office tasks
    With its eye-catching exclusive design this PC is fully equipped and based on standard desktop technology.
  • Stay connected and save power
    Be ready for instant communication and a significantly reduced energy bill with the alternative Low Power Active mode and highly-efficient integrated power-supply.
  • Superb usability
    Thanks to horizontal or vertical operations you have an efficient working environment.
Fujitsu ESPRIMO Q556 - mini PC - Core i3 6100T 3.2 GHz - 4 GB - HDD 500 GB - UK
Personal computer - mini PC
Region: United Kingdom
Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 3Gb/s - 5400 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 530 Shared Video Memory (UMA)
GigE, 802.11a, 802.11b/g/n, Wi-Fi 5
Keyboard
OS Provided
Windows 10 Home 64-bit Edition
Software Included
Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Fujitsu DeskUpdate, Windows 10 Home 64-bit recovery DVD
18.6 cm x 19.1 cm x 5.5 cm
1.6 kg
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Mini PC
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
Scroll
Ethernet Controller
Realtek RTL8111GN
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 2.5" , 1 (total) / 1 (free) x external 5.25" Slim Line
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card
2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in/microphone (1 in front) , 2 x USB 2.0 (2 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x DisplayPort , 1 x DVI-D , 1 x serial , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
Power supply
Power Provided
65 Watt
Efficiency
92% at 100% Load, 92% at 50% Load, 90% at 20% Load, 90% at 10% Load
Operating System / Software
OS Provided
Software
18.6 cm
19.1 cm
5.5 cm
1.6 kg
10 °C
35 °C
5 - 85%
