The FUJITSU ESPRIMO Q556/2, featuring full desktop PC functionality in a stylish and compact mini PC, is a real eye-catcher on your desk. The powerful processors provide the performance to meet your daily office needs. The Zero Noise PC function ensures silent operation. An integrated efficient power supply reduces your energy bill. With its innovative low power active mode feature you are ready for instant communication in the modern office. Its compact size and wide range of interfaces make the FUJITSU ESPRIMO Q556/2 your first choice for locations where space saving is key.
- Fujitsu ESPRIMO Q556/2 - mini PC - Core i5 7400T 2.4 GHz - vPro - 8 GB - SSD 256 GB - UK
- Personal computer - mini PC
- Platform Technology
- Intel vPro Platform
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (7th Gen) 7400T / 2.4 GHz (3 GHz) (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s - 2.5"
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 630 Shared Video Memory (UMA)
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect, Fujitsu DeskUpdate, Windows 10 Pro 64-bit recovery DVD
- 18.5 cm x 19 cm x 5.4 cm
- 1.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - carry-in
- Personal computer
- Product Form Factor
- Mini PC
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - 2.5"
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- DVI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 2
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB410
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111GN
- Data Link Protocol
- Remote Management Protocol
- DMI, CIM
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 0 (free) x internal 2.5" , 1 (total) / 1 (free) x external 5.25"
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 1 (free) x M.2 Card - 2280
- 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 2 x USB 2.0 (2 rear) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x DisplayPort , 1 x DVI-D , 1 x serial , 1 x LAN (Gigabit Ethernet) - RJ-45
- Included Accessories
- VESA cover
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- FCC Class B certified, TUV GS, EN 61000-3-2, WHQL, CCC, RoHS, WEEE, CEL, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 92% at 100% Load, 92% at 50% Load, 90% at 20% Load, 90% at 10% Load
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 18.5 cm
- 19 cm
- 5.4 cm
- 1.6 kg
- 10 °C
- 35 °C
- 5 - 85%
