Fujitsu Esprimo Q556/2 Intel Core i3-6100T 4GB 500GB Windows 10 Pro
Quicklinx: D2KFWS00 Mfr#: VFY:Q5562P23HOGB
  • Core i3
  • IEEE 802.11n
The Fujitsu ESPRIMO Q556/2, featuring full desktop PC functionality in a stylish and compact mini PC, is a real eye-catcher on your desk. The powerful processors provide the performance to meet your daily office needs. The Zero Noise PC function ensures silent operation. An integrated 90%-efficient power supply reduces your energy bill. With its innovative Low Power Active Mode feature you are ready for instant communication in the modern office. Its compact size and wide range of interfaces make the Fujitsu ESPRIMO Q556/2 your first choice for locations where space saving is key.
Fujitsu ESPRIMO Q556/2 - mini PC - Core i3 6100T 3.2 GHz - 4 GB - HDD 500 GB
Personal computer - mini PC
Region: United Kingdom
Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 5400 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 530 Shared Video Memory (UMA)
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Adobe Reader, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect, Fujitsu DeskUpdate, Windows 10 Pro 64-bit recovery DVD
18.5 cm x 19 cm x 5.4 cm
1.6 kg
Limited warranty - 1 year - carry-in
Personal computer
Product Form Factor
Mini PC
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
High Definition Audio
Input Device
Mouse
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111GN
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 2.5" , 1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card - 2230 , 1 (total) / 1 (free) x M.2 Card - 2280
1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 2 x USB 2.0 (2 rear) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x DisplayPort , 1 x DVI-D , 1 x serial , 1 x LAN (Gigabit Ethernet) - RJ-45
VESA cover
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, EN 61000-3-2, WHQL, RoHS, WEEE, cCSAus, China RoHS
Power supply
Power Provided
65 Watt
Efficiency
92% at 100% Load, 92% at 50% Load, 90% at 20% Load, 90% at 10% Load
Operating System / Software
OS Provided
Software
18.5 cm
19 cm
5.4 cm
1.6 kg
10 °C
35 °C
5 - 85%
