The FUJITSU ESPRIMO P957/E94+ desktop provides high manageability, performance and expandability. The Zero Noise PC function supports a pleasant working environment, and the efficient power supply reduces your energy bills. With its innovative Low Power Active Mode feature you are ready for instant communication in the modern office.
- Fujitsu ESPRIMO P957/E94+ - micro tower - Core i5 7500 3.4 GHz - vPro - 8 GB - SSD 256 GB - UK
- Personal computer - micro tower
- Platform Technology
- Intel vPro Platform
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 630 Shared Video Memory (UMA)
- Audio Output
- 5.1 channel surround
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- DeskView Client, DeskView Instant BIOS Management, Workplace Protect, Windows 10 Pro 64-bit recovery DVD
- 18 cm x 30.4 cm x 37.5 cm
- Limited warranty - 3 years - carry-in
- Personal computer
- Product Form Factor
- Micro tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q270
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 7
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- DVI, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB410
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x internal 2.5" , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 1 (free) x external 3.5" , 2 (total) / 1 (free) x external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 2 (total) / 2 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 0 (free) x M.2 Card - 2280
- 1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 5 x USB 2.0 (2 front, 2 rear, 1 internal) , 6 x USB 3.0 (2 front, 4 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x DisplayPort , 1 x DVI-D , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 280 Watt
- Efficiency
- 94% at 50% Load, 90% at 20% Load, 86% at 10% Load, 93% at 100% Load
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
- 18 cm
- 30.4 cm
- 37.5 cm
- 10 °C
- 35 °C
- 5 - 85%
