The Fujitsu ESPRIMO P556/E85+ desktop provides high-quality computing for your daily office tasks. It supports attractive price points and delivers the continuity needed for daily operations. To meet your specific hardware needs it can be either individually configured or customized.
- Fujitsu ESPRIMO P556 E85+ - micro tower - Core i3 6100 3.7 GHz - 4 GB - HDD 500 GB
- Personal computer - micro tower
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 530 Shared Video Memory (UMA)
- Audio Output
- 5.1 channel surround
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence
- Software Included
- Microsoft Office (Trial), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Professional (64-bit)
- 17.5 cm x 42.5 cm x 35.3 cm
- 9 kg
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Micro tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- DVI, HDMI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB410
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111G
- Data Link Protocol
- Remote Management Protocol
- DMI, CIM
- Wake on LAN (WoL), PXE support
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 1 (free) x external 3.5" x 1/3H , 2 (total) / 1 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 2 (total) / 2 (free) x PCIe x1 - full-height
- 1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 2 x USB 3.0 (2 rear) , 1 x DisplayPort , 1 x DVI-D , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) - RJ-45
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- FCC Class B certified, WHQL, CCC, RoHS, WEEE, cCSAus, China RoHS
- Power supply
- Voltage Required
- Power Provided
- 280 Watt
- Efficiency
- 83% at 20% Load, 86% at 50% Load, 85% at 100% Load
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
- 17.5 cm
- 42.5 cm
- 35.3 cm
- 9 kg
- 10 °C
- 35 °C
- 5 - 85%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
