The FUJITSU ESPRIMO K557/24 All-in-One desktop PC supports the budget-driven, modern workplace: streamlined workspace, reduced complexity, with no compromise in performance. This all-rounder combines powerful processors and advanced interfaces in a compact, all-in-one design designed for future-oriented applications. For ergonomic comfort, it features an anti-glare display, wide viewing angles, height adjustment and low noise.
- Fujitsu ESPRIMO K557/24 - all-in-one - Core i5 6400T 2.2 GHz - 8 GB - SSD 256 GB - LED 23.8" - UK
- Personal computer - all-in-one
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (6th Gen) 6400T / 2.2 GHz (, up to 2.8 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s - 2.5"
- Optical Storage
- DVD SuperMulti
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel HD Graphics 530 Shared Video Memory (UMA)
- Camera
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Fujitsu DeskUpdate, Windows 10 Pro 64-bit recovery DVD
- 56 cm x 9.3 cm x 36.8 cm
- 6.5 kg
- Limited warranty - 1 year - carry-in
- Personal computer
- Product Form Factor
- All-in-one - with tilt/swivel/height adjustable stand
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.2 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2400 MHz
- Slots
- 2 (Total) / 1 (empty)
- Dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - 2.5"
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- LED
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Response Time
- 14 ms
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare, WideView
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel
- Resolution
- Full HD
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB410
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
Audio Input
- Stereo microphone
- Ethernet Controller
- Realtek RTL8111G
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Remote Management Protocol
- DMI, CIM
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 0 (free) x internal 2.5" , 1 (total) / 0 (free) x external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x memory , 1 (total) / 0 (free) x M.2 Card - 2230
- 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 3 x USB 2.0 (3 rear) , 1 x LAN - RJ-45 , 1 x audio line-out/headphones , 1 x audio line-in/microphone , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse
- Included Accessories
- Stand
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- FCC Class B certified, WHQL, RoHS, WEEE, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 170 Watt
- Efficiency
- 87% at 20% Load, 90% at 50% Load, 84% at 10% Load, 87% at 100% Load
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
- Dimensions & Weight Details
- 56 cm - 9.3 cm - 36.8 cm - 6.5 kg - without stand , 56 cm - 25.8 cm - 41.1 cm - 9.7 kg - with stand
- 56 cm
- 9.3 cm
- 36.8 cm
- 6.5 kg
- 10 °C
- 35 °C
- 5 - 85%
