Fujitsu ESPRIMO E920 PCs give you the absolute highest PC manageability, performance and expandability. These Zero Noise PCs help you focus on your work and with 94% efficient power supply with 0-Watt technology, you'll also save on energy costs. The use of identical components ensures perfect infrastructure compatibility. At retirement, Fujitsu's distinctive EraseDisk function wipes your data securely.
Green IT
Fujitsu is committed to eliminating the use of harmful and potentially harmful substances in its products and production processes in order to minimize risk to end users and to the environment. This strategy is captured in Environmental Guideline FTS03230 and forms the basis on which all Fujitsu's products are designed. Especially for Fujitsu ESPRIMO PCs this means that all used printed circuit boards are halogen free. Furthermore they are compliant with several certificates awarding environmental conscience such as ENERGY STAR and EPEAT. -
Energy Efficiency
The Fujitsu ESPRIMO E920 features latest technology regarding Intel chipset and processor and optional an up to 94% energy efficient power supply. Furthermore it delivers enhanced power management settings and optional 0-Watt power consumption in off-mode. -
Manageability
Maximum system security and manageability are of critical importance to IT managers. With the Intel vPro Technology and the integrated Intel Active Management Technology (iAMT), Intel is seeking to improve these levels still further, in the deskbound and notebook sector. The Fujitsu ESPRIMO E920 Series supports Intel vPro technology - simple administration made easier. -
Flexibility
Each business has unique, specific requirements to its IT infrastructure. You have the freedom of choice in getting systems which perfectly fit in your specific environment with hardware, software, add-on and lifecycle management.
- Fujitsu ESPRIMO E920 0-Watt - SFF - Core i5 4590 3.3 GHz - vPro - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor - administrator password, system password, hard drive password, USB port control
- Platform Technology
- Intel vPro Platform
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (4th Gen) 4590 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB L3 Cache
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 4600 Shared Video Memory (UMA)
- Audio Output
- 5.1 channel surround
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro Licence
- Software Included
- Drivers & Utilities, Adobe Reader, Fujitsu Recovery, Microsoft Office 2013 (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect, Windows 7 Professional (32/64 bits) / Windows 8.1 Pro 64-bit Twin-Pack recovery DVD
- 34 cm x 38.2 cm x 9.8 cm
- 10 kg
- Manufacturer Selling Program
- Fujitsu proGREEN Selection
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel Q87
Cache Memory
- Installed Size
- L3 Cache - 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Max Allocated RAM Size
- 1782 MB
- Video Interfaces
- VGA, DVI, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB410
- Interface
- PS/2
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Scroll
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Remote Management Protocol
- DMI 2.0
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 0 (free) x internal 3.5" , 1 external 3.5" , 1 (total) / 0 (free) x external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 2 (total) / 2 (free) x PCIe x1 - low-profile
- 1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 8 x USB 2.0 (4 front, 4 rear) , 2 x USB 3.0 (2 rear) , 1 x VGA , 1 x DisplayPort , 1 x DVI-D , 1 x serial , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet)
- Administrator password, system password, hard drive password, USB port control
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 280 Watt
- Efficiency
- 92%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
- 34 cm
- 38.2 cm
- 9.8 cm
- 10 kg
- 10 °C
- 35 °C
- 5 - 85%
