Fujitsu Esprimo D956 Intel Core i5-6600 8GB 256GB SSD Windows 10 Professional
Quicklinx: BZR5WS00 Mfr#: VFY:D0956P751GGB
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
The Fujitsu ESPRIMO D956/E94+ desktop provides high manageability, performance and expandability. The Zero Noise PC function supports a pleasant working environment, and the efficient power supply will reduce your energy bills. With its advanced low power active mode you are ready for instant communication in the modern office.
  • Zero Noise PC
    Ensures pleasant working environment due to completely quiet system and fan stop in standard operations.
  • Stay connected and save power
    Be ready for instant communication and a significantly reduced energy bill with the advanced low power active mode and highly-efficient integrated power-supply.
  • Great energy efficiency coupled with performance
    You will enjoy low power consumption combined with high levels of performance.
Fujitsu ESPRIMO D956/E94+ - SFF - Core i5 6600 3.3 GHz - vPro - 8 GB - SSD 256 GB - UK
Personal computer - small form factor
Platform Technology
Intel vPro Platform
Region: United Kingdom
Intel Core i5 (6th Gen) 6600 / 3.3 GHz (, up to 3.9 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s - M.2
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 530 Shared Video Memory (UMA)
Audio Output
5.1 channel surround
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro Licence
Software Included
Adobe Reader, Microsoft Office (Trial), Fujitsu Recovery, McAfee Multi Access (60 days trial), Windows 7 Professional (32/64 bits) / Windows 10 Pro 64-bit Twin-Pack recovery DVD
33.2 cm x 33.8 cm x 8.9 cm
8 kg
Manufacturer Selling Program
Fujitsu proGREEN Selection
Limited warranty - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q170
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2
1 x 256 GB
Interface Type
SATA 6Gb/s
Mainstream
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
5
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
PS/2
Localization & Layout
Mouse
Optical
USB
Scroll
Ethernet Controller
Intel I219-LM
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x external 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x M.2 2280
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 2 (total) / 2 (free) x PCIe x1 - low-profile
1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 6 x USB 3.0 (2 front, 4 rear) , 2 x DisplayPort , 1 x DVI-D , 1 x serial , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
Power supply
Power Provided
280 Watt
Efficiency
94% at 50% Load, 90% at 20% Load, 86% at 10% Load, 93% at 100% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
33.2 cm
33.8 cm
8.9 cm
8 kg
10 °C
35 °C
5 - 85%
