Fujitsu Esprimo D556/2 Intel Core i7-7700 8GB 256GB SSD Win 10 Pro
Quicklinx: D2KDWS00 Mfr#: VFY:D5562P27SOGB
  • Core i7
The FUJITSU ESPRIMO D556/E85+ desktop provides high-quality computing for your daily office tasks. It supports attractive price points and delivers the continuity needed for daily operations.
Fujitsu ESPRIMO D556/2/E85+ - SFF - Core i7 7700 3.6 GHz - 8 GB - SSD 256 GB - UK
Personal computer - small form factor
Region: United Kingdom
Intel Core i7 (7th Gen) 7700 / 3.6 GHz (, up to 4.2 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s - 2.5"
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 630 Shared Video Memory (UMA)
Audio Output
5.1 channel surround
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Adobe Reader, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect, Windows 10 Pro 64-bit recovery DVD
33.2 cm x 33.8 cm x 8.9 cm
8 kg
Limited warranty - 1 year - carry-in
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD - 2.5"
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
VGA, DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111G
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25" , 1 (total) / 1 (free) x external 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x memory , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 0 (free) x PCIe x1 - low-profile , 1 (total) / 1 (free) x M.2 Card - 2280
1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DisplayPort , 1 x DVI-D , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA
VGA extension card
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, CEL, cCSAus
Power supply
Power Provided
280 Watt
Efficiency
75% at 10% Load, 85% at 50% Load, 84% at 100% Load, 83% at 20% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
33.2 cm
33.8 cm
8.9 cm
8 kg
10 °C
35 °C
5 - 85%
