Fujitsu Esprimo D556/2 Intel Core i3-7100 4GB 128GB SSD Win 10 Pro
Quicklinx: D2K7WS00 Mfr#: VFY:D5562P23AOGB
  • Core i3
The Fujitsu ESPRIMO D556/E85+ desktop provides high-quality computing for your daily office tasks. It supports attractive price points and delivers the continuity needed for daily operations. Your valuable business data is protected by the TPM controller.
Fujitsu ESPRIMO D556/2/E85+ - SFF - Core i3 7100 3.9 GHz - 4 GB - SSD 128 GB - UK
Personal computer - small form factor
Region: United Kingdom
Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - SATA 6Gb/s - 2.5"
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 630 Shared Video Memory (UMA)
Audio Output
5.1 channel surround
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Adobe Reader, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect, Windows 10 Pro 64-bit recovery DVD
33.2 cm x 33.8 cm x 8.9 cm
8 kg
Limited warranty - 1 year - carry-in
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.9 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
SSD - 2.5"
1 x 128 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Max Allocated RAM Size
1782 MB
Video Interfaces
VGA, DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111G
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25" , 1 (total) / 1 (free) x external 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x memory , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 0 (free) x PCIe x1 - low-profile , 1 (total) / 1 (free) x M.2 Card - 2280
1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DisplayPort , 1 x DVI-D , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA
VGA extension card
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, CEL, cCSAus
Power supply
Power Provided
280 Watt
Efficiency
75% at 10% Load, 85% at 50% Load, 84% at 100% Load, 83% at 20% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
33.2 cm
33.8 cm
8.9 cm
8 kg
10 °C
35 °C
5 - 85%
