Fujitsu E24-8 TS Pro 23.8" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: CZ8RWS00 Mfr#: BDL:K1598V160-UK
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£110.56 ex VAT
£132.67 inc VAT
The FUJITSU display B24-8 TS Pro is made for intensive office work. With visual and mechanical ergonomics this stylish display enables fatigue-free working for hours in front of the screen. The large 23.8-inch screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
Fujitsu E24-8 TS Pro - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
55.3 cm x 20.9 cm x 37.2 cm
3.6 kg
United Kingdom
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
FCC Class B certified, TUV GS, BSMI, EN 60950, SASO, CCC, DDC/CI, RoHS, WEEE, S Mark, cTUVus, KC, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, ISO9241-307, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Energy Class
Class A+
25 kWh
17 W
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 6500K, 7500K
OSD Languages
Danish, Hebrew, Czech, Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
HDCP, Overdrive technology, ECO button, High Frame Rate Control (Hi-FRC), Low Blue Light Mode
Matte black
55.3 cm x 20.9 cm x 37.2 cm - with stand
3.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m
United Kingdom
Security Slot Type
Kensington security slot
14.95 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
0.1 Watt
Dimensions & Weight Details
With stand - width: 55.3 cm - depth: 20.9 cm - height: 37.2 cm - weight: 3.6 kg , Without stand - width: 55.3 cm - depth: 6.35 cm - height: 33.02 cm - weight: 3.3 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
Fujitsu E24-8 TS Pro 23.8 Bundle deal on Fujitsu E24-8 TS Pro 23.8" 1920x1080 5ms VGA DVI HDMI LED Monitor
£209.73
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Fujitsu
Price Range Ex VAT: 100 - 150
