Fujitsu E20T-7 19.5" 1600x900 5ms VGA DVI LED Monitor
Quicklinx: CZ8MWS00 Mfr#: BDL:K1538V161-UK
Diagonal Size: 19.5in
Max Resolution: 1600 x 900
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), DVI
£97.01 ex VAT
£116.41 inc VAT
Marketing description is not available.
Fujitsu E Line E20T-7 - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Energy Class
Class A+
Energy Consumption per Year
15 kWh
Power Consumption (On mode)
10 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.2712 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Matte black
46.97 cm x 20.294 cm x 36.05 cm
3.75 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, ISO 9241-307 Class 2
Display Type
Energy Class
Class A+
15 kWh
Diagonal Size
19.5"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.2712 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
HDCP, High Frame Rate Control (Hi-FRC)
Matte black
46.97 cm x 20.294 cm x 36.05 cm - with stand
3.75 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , Audio line-in , Audio line-out
Mechanical
Height, tilt
Tilt Angle
-5/+35
Height Adjustment
105 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D - 1.8 m , 1 x audio cable - 1.8 m
MTBF
50,000 hour(s)
United Kingdom
Input Voltage
10 W
Power Consumption (Typical)
16.3 Watt
Power Consumption (Off Mode)
0.1 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 46.97 cm - depth: 5.98 cm - height: 27.76 cm - weight: 2.2 kg
ENERGY STAR Certified
20 - 80%
Response Time: 5ms
Interfaces: DVI
Brand: Fujitsu
