Your basket is empty
Fujitsu E20T-7 19.5" 1600 x 900 5ms D-SUB DVI LED Monitor Speakers
Quicklinx: 9T77WS00 Mfr#: BDL:K1538V160-UK
The Fujitsu display E20T-7 LED comes in a 16:9 format with a trendy style. There is no compromise in picture quality and energy efficiency. It is the best choice to get high pixel density with restricted desk space. It is easy-to-use and once it is installed you never have to adjust it again - proven Fujitsu quality.
Fujitsu E20T-7 LED - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.2712 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
46.97 cm x 20.294 cm x 36.05 cm
2.7 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, Directive 2004/108/EEC, TCO Displays 6.0, EAC, VESA MIS-D 100 C, ISO9241-307
3 years warranty
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.2712 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
180 MHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
HDCP, High Frame Rate Control (Hi-FRC)
Matte black
46.97 cm x 20.294 cm x 36.05 cm - with stand
2.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-3.5/+21.5
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m
MTBF
50000 hour(s)
United Kingdom
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
Power Consumption Stand by
0.1 Watt
Windows 8
Dimensions & Weight Details
With stand - width: 46.97 cm - depth: 20.294 cm - height: 36.05 cm - weight: 2.7 kg , Without stand - width: 46.97 cm - depth: 5.98 cm - height: 27.76 cm - weight: 2.2 kg
ENERGY STAR Certified
Limited warranty - 3 years
