The Fujitsu Display E19-7 LED combines comfortable ergonomics with best-in-class energy saving technology like ECO operation mode. Environmentally friendly LED technology with unique, high efficient energy saving solutions like ECO operation mode and ECO standby. Convenient and fatigue-proof-usage due to visual ergonomics for the office ensured by wide viewing angle technology.
- Fujitsu E19-7 LED - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Energy Class
- Class A+
- Energy Consumption per Year
- 21 kWh
- Power Consumption (On mode)
- 14 W
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.293 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 41.4 cm x 20.9 cm x 39.1 cm
- 3.52 kg
- Localisation
- United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, Directive 2004/108/EEC, EAC, ISO 9241-307 Class 1
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 21 kWh
- Diagonal Size
- 19"
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.293 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 7500K
- OSD Languages
- Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- sRGB colour management, HDCP, Eco-Mode, ECO button, High Frame Rate Control (Hi-FRC)
- Black
- 41.4 cm x 20.9 cm x 39.1 cm - with stand
- 3.52 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1.5 Watt
- VGA , Audio line-out , DVI-D (HDCP) , Audio line-in , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m
- MTBF
- 70,000 hour(s)
- Localisation
- United Kingdom
- Input Voltage
- 14 W
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Stand by
- 0.22 Watt
- Power Consumption Sleep
- 0.19 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 41.4 cm - depth: 20.9 cm - height: 39.1 cm - weight: 3.52 kg , Without stand - width: 41.4 cm - depth: 6.4 cm - height: 34.9 cm - weight: 3.09 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - pick-up and return
- 5 °C
- 35 °C
