Product
Fujitsu E19-7 19" 1280x1024 8ms VGA DVI LED Monitor
Quicklinx: CZ8NWS00 Mfr#: BDL:K1482V161-UK
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£126.34 ex VAT
£151.60 inc VAT
The Fujitsu Display E19-7 LED combines comfortable ergonomics with best-in-class energy saving technology like ECO operation mode. Environmentally friendly LED technology with unique, high efficient energy saving solutions like ECO operation mode and ECO standby. Convenient and fatigue-proof-usage due to visual ergonomics for the office ensured by wide viewing angle technology.
Fujitsu E19-7 LED - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class A+
Energy Consumption per Year
21 kWh
Power Consumption (On mode)
14 W
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
41.4 cm x 20.9 cm x 39.1 cm
3.52 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, TCO '06, Directive 2004/108/EEC, EAC, TCO Displays 7.0, ISO 9241-307 Class 1
3 years warranty
Display Type
Energy Class
Class A+
21 kWh
14 W
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
sRGB colour management, HDCP, Eco-Mode, ECO button, High Frame Rate Control (Hi-FRC)
41.4 cm x 20.9 cm x 39.1 cm - with stand
3.52 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , Audio line-out , DVI-D (HDCP) , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
17 Watt
Power Consumption Stand by
0.22 Watt
Power Consumption Sleep
0.19 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 41.4 cm - depth: 20.9 cm - height: 39.1 cm - weight: 3.52 kg , Without stand - width: 41.4 cm - depth: 6.4 cm - height: 34.9 cm - weight: 3.09 kg
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
Fujitsu E19-7 19 Bundle deal on Fujitsu E19-7 19" 1280x1024 8ms VGA DVI LED Monitor
£226.10
Diagonal Size: 19in
Response Time: 8ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Fujitsu
Price Range Ex VAT: 100 - 150
