Combining leading performance architecture with automated quality of service management the Fujitsu Storage ETERNUS DX series aligns storage resources with business priorities, thus enabling higher system utilization and delivering increased system consolidation capabilities and a faster ROI.
The scalable and unified Fujitsu Storage ETERNUS DX100 S3 delivers enterprise-class functionality to small and medium-sized companies and subsidiaries with an excellent price/performance ratio. It is the perfect solution when consolidating data for server virtualization, e-mail, databases and business applications as well as centralized file services. Simple, intuitive system management, highly flexible network connectivity and the option of field upgrades to higher system classes significantly reduce operational and migration costs. The ETERNUS DX family architecture lets customers benefit from software options, such as thin provisioning, automatic storage tiering and quality of service management even as early as the entry-level class. This all contributes to better business support.
- Fujitsu ETERNUS DX 100 S3 Controller Enclosure - storage enclosure
- Storage enclosure
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 24 (max)
- Supported Drives
- SAS-3
- Hard Drive
- 0 - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 48.2 cm x 64.5 cm x 8.8 cm
- 35 kg
- 3-year warranty
- Storage enclosure
- Enclosure Type
Chassis
- Supported Devices / Modules Qty
- 24
- Supported Drives
- SAS-3
- CPU
- No CPU
Hard Drive
- Hot-swap
- Capacity
- 0
- Expansion Bays
- 24 (total) / 24 (free) x hot-swap - 2.5"
- 92% efficiency power supply
- VCCI, C-Tick, CISPR 22 Class A, GOST, GS, EN55024, EN55022 Class A, CB, ICES-003 Class A, FCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FCC CFR47, GOST-R, CSA C22.2 No. 60950-1, Directive 2004/108/EC, Directive 2006/95/EC, VCCI Class A, Directive 2011/65/EC, AS/NZS CISPR 22, CNS 13438
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 48.2 cm
- 64.5 cm
- 8.8 cm
- 35 kg
- Limited warranty - 3 years - on-site
- 10 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 49 dBA
