Product
Fujitsu Dock Only (no AC or Mains Cable)
Quicklinx: 9QGCWS00 Mfr#: S26391-F1187-L100
Flexibility, expandability, desktop replacement and investment protection are just few benefits of Fujitsu's docking options. The port replicators are the perfect docking solutions for LIFEBOOK notebooks, STYLISTIC tablets and CELSIUS mobile workstations. In the office or at home it takes just a second to attach your device to the port replicator and get connected to peripherals such as an external display, keyboard and mouse. Your workplace is simple and tidy while you are ready to work with your Fujitsu device.
Fujitsu - port replicator
Port replicator
33.65 cm x 15.16 cm x 4.2 cm
450 g
LIFEBOOK T902
Port replicator
33.65 cm
15.16 cm
4.2 cm
450 g
1 x audio - line-out/headphones - mini-phone stereo 3.5 mm , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - DVI-Digital (dual link)
Security lock slot (cable lock sold separately), on/off switch
Fujitsu LIFEBOOK T902
9QGC C2G HDMI to DisplayPort Adapter Converter In Stock £36.21
9QGC C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £21.89
9QGC C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £23.89
9QGC C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
9QGC C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £15.66
9QGC C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.05
