Your basket is empty
Fujitsu Celvin QR802 Diskless 1U Rackmount NAS
Quicklinx: 9B14WS00 Mfr#: S26341-F103-L896
  • Atom
The Fujitsu CELVIN NAS Server QR802 is the ideal solution for file sharing, end to end backup options and SAN (Storage Area Network) integration for SMB customers - enabling centralized data management at a reasonable price. It has dual power supplies for superior reliability with large storage capacity and is designed to be rack mounted right alongside other networked enterprise equipment.
Fujitsu CELVIN NAS Server QR802 - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
0 GB
0 (installed) / 4 (max)
43.9 cm x 49.9 cm x 4.4 cm
7.6 kg
United Kingdom, Europe
1 x Intel Atom 2.13 GHz
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
Power Redundancy
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
0 GB
43.9 cm
49.9 cm
4.4 cm
7.6 kg
Enclosure Colour
Black with copper trays
Built-in Devices
Led panel
Processor / Memory
Processors Installed
RAM
1 GB DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID - internal
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Max Storage Devices Qty
4
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap
Network / Transport Protocol
TCP/IP, UDP/IP, NTP, iSCSI, FTP, DHCP, Bonjour, DDNS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, VLAN support, wake on LAN (WOL), E-mail alert, print server, IPv6 support, MySQL server, web server, torrent/P2P data exchange, file sharing, Access Control List (ACL) support, SSH support, Jumbo Frames support, DHCP server, Samba support, FTP server, BitTorrent Client, UPnP Media Server, IPv4 support, SQLite server, TwonkyMedia server, PXE support, LACP support, Receive Side Scaling (RSS), Link Aggregation Control Protocol (LACP), DHCP client, VPN Server
Encryption Algorithm
AES, SSL, TLS, TKIP, WPA, WPA2, WEP
IEEE 802.1Q, IEEE 802.3ad (LACP), IEEE 802.1x, UPnP
Expansion Bays
4 (total) / 4 (free) x external - 2.5" / 3.5"
5 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 2 x eSATA , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
FCC Class A certified
Rack mounting kit
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
52 Watt
Power Provided
250 Watt
Software Included
Drivers & Utilities
9B14 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
9B14 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.29
9B14 C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
9B14 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
9B14 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
9B14 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
9B14 C2G USB 2.0 To Fast Ethernet Adapter In Stock £19.05
