Fujitsu Celsius W550 Core i7-6700 8gb 1tb Windows 10 Pro
Quicklinx: CS3RWS00 Mfr#: VFY:W5500W27AGGB
Processor Type: Core i7
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Core i7
£773.14 ex VAT
£927.76 inc VAT
Has your desktop reached the limit in terms of performance, scalability and expandability? Than the Fujitsu CELSIUS W550 desktop workstation is your ideal choice, especially for video editing, MCAD / electrical CAD or architecture, engineering and construction applications. Enjoy low-noise emissions for a quiet and efficient working environment.
  • Abundant performance
    Enjoy impressive professional graphics and storage capacity.
  • Whisper-quiet design
    Enjoy a silent workplace environment thanks to low noise emission.
  • Multi-monitor experience
    Enjoy maximum viewing capabilities and increase your productivity.
Fujitsu Celsius W550 - micro tower - Core i7 6700 3.4 GHz - 8 GB - 1 TB - QWERTY UK
Workstation - micro tower
Region: United Kingdom
1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (4 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
PCIe x16 - NVIDIA Quadro K620 / Intel HD Graphics 530 Shared Video Memory (UMA)
Video Memory
2 GB
Audio Output
5.1 channel surround
GigE
OS Provided
17.5 cm x 41.9 cm x 39.5 cm
11 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Workstation
Product Form Factor
Micro tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe x16
Graphics Processor
Video Memory
2 GB
Max Allocated RAM Size
1782 MB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB410
PS/2
Localization & Layout
QWERTY UK
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x internal 2.5" , 2 (total) / 1 (free) x internal 3.5" , 2 (total) / 2 (free) x external 3.5" , 2 (total) / 1 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 2 (free) x PCIe 3.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x4 mode) , 1 (total) / 0 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x M.2 Card
1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 7 x USB 3.0 (2 front, 4 rear, 1 internal) , 3 x DisplayPort , 1 x DVI-D , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DVI-I (dual link)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
Power supply
Nominal Voltage
Power Provided
300 Watt
Efficiency
90% at 100% Load, 88% at 20% Load, 92% at 50% Load, 84% at 10% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect
ENERGY STAR Certified
ENERGY STAR Version
6.1
17.5 cm
41.9 cm
39.5 cm
11 kg
10 °C
35 °C
5 - 85%
Fujitsu Celsius W550 Core i7-6700 8gb 1tb Windows 10 Pro Bundle deal on Fujitsu Celsius W550 Core i7-6700 8gb 1tb Windows 10 Pro
£958.36
saving £8.33
£872.31
Storage Type: HDD
Processor Model: I7-6700
Type: Workstation
Case Style: Micro tower
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Brand: Fujitsu
Price Range Ex VAT: 750 - 1000
