Fujitsu Celsius W530 Intel Core i5-4690 8GB 500GB Windows 7 Professional 64-bit
Quicklinx: B4Y3WS00 Mfr#: VFY:W5300W450GGB
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
If you need a powerful entry-level workstation, Fujitsu's CELSIUS W530 is the ideal choice. The FUJITSU CELSIUS W530 workstation gives you the graphics capabilities and performance you need for entry-level 3D/CAD or DCC applications. Comprehensive ISV certifications ensure your professional applications run smoothly. Your workplace is silent and user-friendly thanks to best-in-class noise emissions. Plus, this compact workstation is individually configurable and allows easy tool-less expansion for greater working flexibility.
  • Workstation application field
    The Fujitsu Celsius W530 is the ideal partner for demanding business environments such as 3D CAD, financial forecasting or digital content creation. Extensive ISV certifications and powerful graphics ensure an exceedance of a PC allowing to get more done in less time.
  • Quiet operation
    Fujitsu workstations offer class-leading low noise emissions for a pleasant working environment. This is achieved through an optimized thermal management system, which makes use of air tunnels to provide efficient airflow within the system.
  • Manageability
    Maximum system security and manageability are of critical importance to IT managers. With the Intel vPro technology and the integrated Intel Active Management Technology (iAMT), Intel is seeking to improve these levels still further, in the deskbound and notebook sector. The Fujitsu Celsius W530 supports Intel vPro technology - simple administration made easier.
  • Flexibility
    Each business has unique, specific requirements to its IT infrastructure. You have the freedom of choice in getting systems which perfectly fit in your specific environment with hardware, software, add-on and lifecycle management.
Fujitsu Celsius W530 - tower - Core i5 4690 3.5 GHz - vPro - 8 GB - Hybrid Drive 500 GB - UK
Workstation - tower - administrator password, system password, hard drive password, USB port control
Platform Technology
Intel vPro Platform
Region: United Kingdom
1 x Intel Core i5 (4th Gen) 4690 / 3.5 GHz (, up to 3.9 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB L3 Cache
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
Hybrid Drive 500 GB - SATA 6Gb/s - 5400 rpm
Optical Storage
DVD SuperMulti
Card Reader
24 in 1
Graphics Controller
PCIe x16 - NVIDIA Quadro K420 / Intel HD Graphics 4600
Video Memory
1 GB
Audio Output
5.1 channel surround - integrated
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro Licence
Software Included
Drivers & Utilities, Adobe Reader, Fujitsu Recovery, Microsoft Office 2013 (Trial), DeskView Client, DeskView Instant BIOS Management, DeskView Integration for Symantec Management Platform, McAfee Multi Access (60 days trial), Workplace Protect
17.5 cm x 41.9 cm x 39.5 cm
11 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Limited warranty - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1150 Socket
Chipset Type
Intel C226
Cache Memory
Installed Size
L3 Cache - 6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
Hybrid Drive
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x RAID - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
24 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Plug-in card
Interface Type
PCIe x16
Graphics Processor
Video Memory
1 GB
Video Interfaces
VGA, DVI, DisplayPort
HDCP Compatible
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Fujitsu KB900
USB
Localization & Layout
Mouse
Optical
USB
Tilt wheel
Integrated
Ethernet Controller
Intel I217-LM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x internal 2.5" , 2 (total) / 1 (free) x internal 3.5" , 2 (total) / 1 (free) x external 3.5" , 2 (total) / 1 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x memory , 1 (total) / 0 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 2 (total) / 2 (free) x PCIe x1 - full-height
1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 8 x USB 2.0 (2 front, 4 rear, 2 internal) , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 2 x DisplayPort , 1 x DVI-D , 1 x serial , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x DVI-I (dual link)
Administrator password, system password, hard drive password, USB port control
Theft/Intrusion Protection
FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
Power supply
Power Provided
300 Watt
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
Blue Angel Compliant
17.5 cm
41.9 cm
39.5 cm
11 kg
10 °C
35 °C
5 - 85%
