If you need a powerful entry-level workstation, Fujitsu's CELSIUS W530 is the ideal choice. The FUJITSU CELSIUS W530 workstation gives you the graphics capabilities and performance you need for entry-level 3D/CAD or DCC applications. Comprehensive ISV certifications ensure your professional applications run smoothly. Your workplace is silent and user-friendly thanks to best-in-class noise emissions. Plus, this compact workstation is individually configurable and allows easy tool-less expansion for greater working flexibility.
Workstation application field
The Fujitsu Celsius W530 is the ideal partner for demanding business environments such as 3D CAD, financial forecasting or digital content creation. Extensive ISV certifications and powerful graphics ensure an exceedance of a PC allowing to get more done in less time. -
Quiet operation
Fujitsu workstations offer class-leading low noise emissions for a pleasant working environment. This is achieved through an optimized thermal management system, which makes use of air tunnels to provide efficient airflow within the system. -
Manageability
Maximum system security and manageability are of critical importance to IT managers. With the Intel vPro technology and the integrated Intel Active Management Technology (iAMT), Intel is seeking to improve these levels still further, in the deskbound and notebook sector. The Fujitsu Celsius W530 supports Intel vPro technology - simple administration made easier. -
Flexibility
Each business has unique, specific requirements to its IT infrastructure. You have the freedom of choice in getting systems which perfectly fit in your specific environment with hardware, software, add-on and lifecycle management.
- Fujitsu Celsius W530 - tower - Core i5 4690 3.5 GHz - vPro - 8 GB - Hybrid Drive 500 GB - UK
- Workstation - tower - administrator password, system password, hard drive password, USB port control
- Platform Technology
- Intel vPro Platform
- Localisation
- Region: United Kingdom
- Processor
- 1 x Intel Core i5 (4th Gen) 4690 / 3.5 GHz (, up to 3.9 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB L3 Cache
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - PC3-12800
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- Hybrid Drive 500 GB - SATA 6Gb/s - 5400 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 24 in 1
- Graphics Controller
- PCIe x16 - NVIDIA Quadro K420 / Intel HD Graphics 4600
- Video Memory
- 1 GB
- Audio Output
- 5.1 channel surround - integrated
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro Licence
- Software Included
- Drivers & Utilities, Adobe Reader, Fujitsu Recovery, Microsoft Office 2013 (Trial), DeskView Client, DeskView Instant BIOS Management, DeskView Integration for Symantec Management Platform, McAfee Multi Access (60 days trial), Workplace Protect
- 17.5 cm x 41.9 cm x 39.5 cm
- 11 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Limited warranty - 3 years - on-site
- Workstation
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4690
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- L3 Cache - 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Unbuffered, dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- Hybrid Drive
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 24 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Plug-in card
- Interface Type
- PCIe x16
- Graphics Processor
- Video Memory
- 1 GB
- Video Interfaces
- VGA, DVI, DisplayPort
- HDCP Compatible
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB900
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Tilt wheel
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x internal 2.5" , 2 (total) / 1 (free) x internal 3.5" , 2 (total) / 1 (free) x external 3.5" , 2 (total) / 1 (free) x external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x memory , 1 (total) / 0 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 2 (total) / 2 (free) x PCIe x1 - full-height
- 1 x audio line-in , 1 x audio line-in/microphone , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 8 x USB 2.0 (2 front, 4 rear, 2 internal) , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 2 x DisplayPort , 1 x DVI-D , 1 x serial , 2 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x DVI-I (dual link)
- Administrator password, system password, hard drive password, USB port control
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, WHQL, RoHS, WEEE, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 300 Watt
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- Blue Angel Compliant
- 17.5 cm
- 41.9 cm
- 39.5 cm
- 11 kg
- 10 °C
- 35 °C
- 5 - 85%
