Fujitsu's CELSIUS R940 is designed to surpass all your expectations. Achieving first-class benchmark results, this reliable, high-end dual processor workstation is individually configurable and optimized for extremely demanding and memory intensive multi-threaded applications in a 24/7 operating environment. Offering the latest NVIDIA GRID graphics virtualization cards, the CELSIUS R940 is your reliable partner for graphics virtualization and high performance computing.
Workstation application field
The FUJITSU CELSIUS R940 is optimized for most compute-intensive, multi-processor applications like simulation, virtual reality, visualization, electronic design, high performance computing (HPC) automation, workstation virtualization and geographic information systems. -
Workstation virtualization in the datacenter
Ideal for workstation consolidation due to multiple users per workstation, increased data security and protection against theft or damage. -
Easy upgrades
Thanks to intelligent design and comfortable cold plug access at front, rapid change and upgrades of hard disk drives is ensured. -
Quiet operation
Fujitsu workstations offer class-leading low noise emissions for a pleasant working environment. This is achieved through an optimized thermal management system, which makes use of air tunnels to provide efficient airflow within the system.
- Fujitsu Celsius R940 - tower - Xeon E5-2630V3 2.4 GHz - vPro - 16 GB - SSD 256 GB - UK
- Workstation - tower - administrator password, system password, hard drive password, USB port control, Fujitsu EraseDisk, supports AHCI mode
- Platform Technology
- Intel vPro Platform
- Processor
- 2 x Intel Xeon E5-2630V3 / 2.4 GHz (, up to 3.2 GHz, (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 40 MB
- Cache Per Processor
- 20 MB
- RAM
- 16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Card Reader
- 24 in 1
- Graphics Controller
- No graphics
- Audio Output
- Integrated
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro Licence
- Software Included
- Microsoft Office 2013 (Trial), DeskView Client, DeskView Instant BIOS Management, DeskView Integration for Symantec Management Platform, McAfee Multi Access (60 days trial), Workplace Protect
- 18.6 cm x 61.8 cm x 43 cm
- 20 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Workstation
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
- CPU
- Intel Xeon E5-2630V3
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 8-core
- CPU Qty
- 2
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 40 MB
- 20 MB
RAM
- Installed Size
- 16 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 12 (empty)
- Registered
- Configuration Features
- 4 x 4 GB
- RAM Supported
- PC4-17000 - 256 GB registered - ECC , PC4-17000 - 512 GB Load-Reduced - ECC
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 10
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 24 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Integrated
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Fujitsu KB900
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Tilt wheel
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I217-LM, I210
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 8 (total) / 7 (free) x internal 2.5" x 1/8H , 4 (total) / 4 (free) x internal 3.5" x 1/3H , 2 (total) / 1 (free) x external 3.5" x 1/3H , 2 (total) / 1 (free) x external 5.25" x 1/2H
- Slots
- 2 (total) / 0 (free) x CPU , 16 (total) / 12 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-height , 4 PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-height (2 processors must be installed)
- 2 x audio line-in (1 rear) , 2 x audio line-out (1 rear) , 9 x USB 2.0 (2 in front) , 4 x USB 3.0 (2 in front) , 2 x LAN (Gigabit Ethernet) - RJ-45
- Administrator password, system password, hard drive password, USB port control, Fujitsu EraseDisk, supports AHCI mode
- Theft/Intrusion Protection
- FCC Class B certified, WHQL, RoHS, WEEE, cCSAus
- Power supply
- Voltage Required
- Power Provided
- 1000 Watt
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- 18.6 cm
- 61.8 cm
- 43 cm
- 20 kg
- 10 °C
- 35 °C
- 5 - 85%
