If you need a powerful yet small workstation, Fujitsu's CELSIUS J550 is the ideal choice for entry-level 3D, CAD, financial applications as well as the healthcare industry. Thanks to its innovative 10 liter design, the CELSIUS J550 small form factor workstation is the first to support standard, full-height graphics cards.
- Fujitsu Celsius J550 - SFF - Core i7 6700 3.4 GHz - 8 GB - HDD 1 TB
- Workstation - small form factor
- Localisation
- Region: United Kingdom
- Processor
- 1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (4 GHz) (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Card Reader
- 24 in 1
- Graphics Controller
- NVIDIA Quadro K620
- Video Memory
- 2 GB
- Audio Output
- 5.1 channel surround
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro Licence
- Software Included
- Microsoft Office (Trial)
- 33.2 cm x 33.8 cm x 8.9 cm
- 9 kg
- Limited warranty - 3 years - on-site
- Workstation
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Localisation
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel C236
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 5
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 24 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 2 GB
- Video Interfaces
- DVI, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Keyboard
Keyboard
- Keyboard Name
- Fujitsu KB900
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Tilt wheel
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Remote Management Protocol
- DMI, CIM
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" x 1/2H
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x4 mode)
- 1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 2 x USB 2.0 (2 in front) , 6 x USB 3.0 , 1 x DisplayPort , 1 x DVI-I (dual link) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
- Power supply
- Voltage Required
- Power Provided
- 280 Watt
- Efficiency
- 91% at 100% Load, 92% at 50% Load, 84% at 10% Load, 90% at 20% Load
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
- 33.2 cm
- 33.8 cm
- 8.9 cm
- 9 kg
- 10 °C
- 35 °C
- 5 - 85%
