Fujitsu Celsius J550 SFF i5-6500 8GB 500GB Windows 7 Professional
Quicklinx: BZV5WS00 Mfr#: VFY:J5500W75ABGB
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
If you need a powerful yet small workstation, Fujitsu's CELSIUS J550 is the ideal choice for entry-level 3D, CAD, financial applications as well as the healthcare industry. Thanks to its innovative 10 liter design, the CELSIUS J550 small form factor workstation is the first to support standard, full-height graphics cards.
Fujitsu Celsius J550 - SFF - Core i5 6500 3.2 GHz - 8 GB - Hybrid Drive 500 GB
Workstation - small form factor
Region: United Kingdom
1 x Intel Core i5 (6th Gen) 6500 / 3.2 GHz (3.6 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
Hybrid Drive 500 GB - SATA 6Gb/s
Optical Storage
DVD SuperMulti
Card Reader
24 in 1
Graphics Controller
NVIDIA Quadro K420
Video Memory
1 GB
Audio Output
5.1 channel surround
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro Licence
Software Included
Microsoft Office (Trial)
33.2 cm x 33.8 cm x 8.9 cm
9 kg
Limited warranty - 3 years - on-site
Workstation
Product Form Factor
Small form factor
Built-in Devices
Speaker
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
Hybrid Drive
1 x 500 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Channel Qty
5
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
24 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
NVIDIA Quadro K420
Video Memory
1 GB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Max Monitors Supported
2
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Keyboard
Keyboard
Keyboard Name
Fujitsu KB900
USB
Mouse
Optical
USB
Tilt wheel
Ethernet Controller
Intel I219-LM
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" x 1/2H
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x4 mode)
1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 2 x USB 2.0 (2 in front) , 6 x USB 3.0 , 1 x DisplayPort , 1 x DVI-I (dual link) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
Power supply
Power Provided
280 Watt
Efficiency
91% at 100% Load, 92% at 50% Load, 84% at 10% Load, 90% at 20% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
33.2 cm
33.8 cm
8.9 cm
9 kg
10 °C
35 °C
5 - 85%
BZV5 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
