Fujitsu Celsius J550 Core i5-6500 8GB 500GB Windows 10 Pro
Quicklinx: CS3JWS00 Mfr#: VFY:J5500W25ABGB
  • Core i5
If you need a powerful yet small workstation, Fujitsu's CELSIUS J550 is the ideal choice for entry-level 3D, CAD, financial applications as well as the healthcare industry. Thanks to its innovative 10 liter design, the CELSIUS J550 small form factor workstation is the first to support standard, full-height graphics cards.
Fujitsu Celsius J550 - SFF - Core i5 6500 3.2 GHz - 8 GB - 500 GB - UK
Workstation - small form factor
Region: United Kingdom
1 x Intel Core i5 (6th Gen) 6500 / 3.2 GHz (3.6 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - PC4-17000
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s
Optical Storage
DVD SuperMulti
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
NVIDIA Quadro K420 / Intel HD Graphics 530 Shared Video Memory (UMA)
Video Memory
1 GB
Audio Output
5.1 channel surround
GigE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
33.2 cm x 33.8 cm x 8.9 cm
9 kg
Limited warranty - 3 years - on-site
Workstation
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Channel Qty
5
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Memory
1 GB
Max Allocated RAM Size
1782 MB
Video Interfaces
DVI, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Keyboard
Keyboard
Keyboard Name
Fujitsu KB410
PS/2
Localization & Layout
Ethernet Controller
Intel I219-LM
Remote Management Protocol
DMI, CIM
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 0 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-height (riser card only)
1 x audio line-in , 1 x audio line-out , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 2 x USB 2.0 (2 internal) , 9 x USB 3.0 (2 front, 6 rear, 1 internal) , 3 x DisplayPort , 1 x DVI-I (dual link) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DVI-D
Riser card
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
FCC Class B certified, WHQL, RoHS, WEEE, cCSAus, China RoHS
Power supply
Nominal Voltage
Power Provided
280 Watt
Efficiency
91% at 100% Load, 92% at 50% Load, 84% at 10% Load, 90% at 20% Load
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Adobe Reader, Microsoft Office (Trial), DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect
33.2 cm
33.8 cm
8.9 cm
9 kg
10 °C
35 °C
5 - 85%
