Product
Fujitsu B27T-7 Pro 27" 1920x1080 5ms VGA DVI DisplayPort LED Monitor
Quicklinx: CZB4WS00 Mfr#: BDL:K1597V140-UK
The B27T-7 Pro is made for intensive office work. With visual and mechanical ergonomics this display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
Fujitsu B27T-7 Pro - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
18 W
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Marble grey
64.4 cm x 22.7 cm x 40.5 cm
8.9 kg
United Kingdom
FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, CCC, DDC/CI, RoHS, WEEE, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TCO Displays 7.0, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
Display Type
Energy Class
Class A+
27 kWh
18 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
HDCP, ECO button, DisplayView, High Frame Rate Control (Hi-FRC)
Marble grey
64.4 cm x 22.7 cm x 40.5 cm - with stand
8.9 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , DVI-D (HDCP) , VGA , Audio line-in , 2 x USB 2.0 downstream (Type A) , USB upstream (Type B)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 24x7 continuous operation
1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.2 Watt
Dimensions & Weight Details
With stand - width: 64.4 cm - depth: 22.7 cm - height: 40.5 cm - weight: 8.9 kg , Without stand - width: 64.4 cm - depth: 7.2 cm - height: 38.3 cm - weight: 5.9 kg
5 °C
35 °C
