Fujitsu B27-8 TE 27" 1920x1080 5ms VGA DVI DP LED IPS Monitor
Quicklinx: DLJ9WS00 Mfr#: BDL:K1641V140-UK
The FUJITSU display B27-8 TE Pro is an advanced widescreen display with 1920 x 1080 resolution that can accommodate two A4 sized documents side-by-side with ease making it ideal for document management applications in the workplace. The display delivers consistent picture quality and has a range of connectivity options ideal for medium- and large-sized businesses.
Fujitsu B27-8 TE Pro - Business Line - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Marble grey
62.13 cm x 29.94 cm x 38.8 cm
6.72 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
3-year warranty
Display Type
Energy Class
Class A+
34 kWh
Diagonal Size
27"
Built-in Devices
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
ECO button, High Frame Rate Control (Hi-FRC), Low Blue Light Mode, Colour Temperature Selection, 24/7 operating mode
Marble grey
62.13 cm x 29.94 cm x 38.8 cm - with stand
6.72 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , HDMI , VGA , Audio line-in , Audio line-out , 2 x USB 3.1 downstream , USB 3.1 upstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
345
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
United Kingdom
Input Voltage
23 W
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.32 Watt
Power Consumption Sleep
0.27 Watt
Dimensions & Weight Details
Without stand - width: 62.13 cm - depth: 6.28 cm - height: 36.89 cm - weight: 4.34 kg , With stand - width: 62.13 cm - depth: 29.94 cm - height: 38.8 cm - weight: 6.72 kg
Shipping Weight
8.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return
5 °C
35 °C
10 - 85% (non-condensing)
