Product
Fujitsu B24-8 TS Pro 23.8" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: CZB0WS00 Mfr#: BDL:K1577V160-UK
The Fujitsu display B24-8 TS Pro is made for intensive office work. With visual and mechanical ergonomics this stylish display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
Fujitsu B24-8 TS Pro - Business Line - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
55.3 cm x 22.94 cm x 34.7 cm
5.6 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, BSMI, EN 60950, SASO, TUV S, CCC, RoHS, WEEE, S Mark, cTUVus, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, ISO9241-307, TUV Rheinland Low Blue Light Certification, TCO Displays 7.0, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class A+
28 kWh
19 W
Diagonal Size
23.8"
Built-in Devices
USB 2.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 6500K, 7500K
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
HDCP, Eco-Mode, ECO button, DisplayView, High Frame Rate Control (Hi-FRC), Low Blue Light Mode, Wide Viewing Angle
55.3 cm x 22.94 cm x 34.7 cm - with stand
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , DVI-D (HDCP) , VGA , Audio line-in , 2 x USB 2.0 downstream , Audio line-out , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
Security Slot Type
Kensington security slot
23 Watt
Power Consumption Stand by
0.21 Watt
Power Consumption Sleep
0.16 Watt
Dimensions & Weight Details
With stand - width: 55.3 cm - depth: 22.94 cm - height: 34.7 cm - weight: 5.6 kg , Without stand - width: 55.3 cm - depth: 6.35 cm - height: 33.02 cm - weight: 3.5 kg
ENERGY STAR Certified
5 °C
35 °C
