The Fujitsu display B24-8 TS Pro is made for intensive office work. With visual and mechanical ergonomics this stylish display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
- Fujitsu B24-8 TS Pro - Business Line - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class D
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 14.4 W
- USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.3 cm x 22.94 cm x 34.7 cm
- 5.6 kg
- Localisation
- United Kingdom
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- FCC Class B certified, TUV GS, BSMI, EN 60950, SASO, TUV S, CCC, RoHS, WEEE, S Mark, cTUVus, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, ISO9241-307, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
- Display Type
- Energy Class
- Class D
- 28 kWh
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 6500K, 7500K
- OSD Languages
- Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- HDCP, Eco-Mode, ECO button, DisplayView, High Frame Rate Control (Hi-FRC), Low Blue Light Mode, Wide Viewing Angle
- Black
- 55.3 cm x 22.94 cm x 34.7 cm - with stand
- 5.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI , DVI-D (HDCP) , VGA , Audio line-in , 2 x USB 2.0 downstream , Audio line-out , USB 2.0 upstream
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
- MTBF
- 70,000 hour(s)
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14.4 W
- Power Consumption SDR (On mode)
- 14.4 kWh/1000h
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.21 Watt
- Power Consumption Sleep
- 0.16 Watt
- Dimensions & Weight Details
- With stand - width: 55.3 cm - depth: 22.94 cm - height: 34.7 cm - weight: 5.6 kg , Without stand - width: 55.3 cm - depth: 6.35 cm - height: 33.02 cm - weight: 3.5 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 5 °C
- 35 °C
