The FUJITSU B23T-7 LED display with excellent ergonomics makes intensive office work extremely comfortable. This highly reliable display offers superb usability and power-saving features to help reduce your labor as well as energy costs. With wide viewing angle technology, flexible connectivity, and easy manageability, the FUJITSU B23T-7 LED Display can help you improve productivity.
Exceeding ergonomics
The human-centric design is gentle on the eyes and healthy for the posture: sophisticated stand with height adjustment including tilt, swivel and optimized viewing ergonomics with wide viewing angle technology. -
Eco system
Eco mode is a preset brightness adjust that fits for typical office environment delivering optimum brightness for most office applications. Eco button comfortably switches between Eco mode and best picture performance. Eco LED indicator makes energy saving visible. -
LED backlight technology
Benefit from ultra-high contrast and allover illumination for less eye strain, economical power consumption and environment-conscious, mercury-free panels.
- Fujitsu B23T-7 LED - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A+
- Energy Consumption per Year
- 25 kWh
- Power Consumption (On mode)
- 17 W
- USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.265 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Marble grey
- 55 cm x 20.4 cm x 35 cm
- 6.2 kg
- Localisation
- United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, VCCI, cUL, EN 60950, GS, SASO, TUV S, DDC/CI, RoHS, WEEE, EN 60601-1-2, S Mark, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, ISO9241-307
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 25 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB 2.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 48 - 76 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 7500K
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, input select, phase, clock, black level
- OSD Languages
- Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- sRGB colour management, HDCP, ECO button, DisplayView, 72% NTSC colour gamut
- Marble grey
- 55 cm x 20.4 cm x 35 cm - with stand
- 6.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1.5 Watt
- DisplayPort , DVI (HDCP) , VGA , Audio line-in , 2 x USB 2.0 downstream , USB 2.0 upstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
- MTBF
- 70,000 hour(s)
- Localisation
- United Kingdom
- Input Voltage
- 17 W
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.16 Watt
- Power Consumption Sleep
- 0.1 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 55 cm - depth: 20.4 cm - height: 35 cm - weight: 6.2 kg , Without stand - width: 55 cm - depth: 6.1 cm - height: 33.1 cm - weight: 3.6 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - pick-up and return
- 5 °C
- 35 °C
