Fujitsu B19-7 LED 19" 1280x1024 8ms VGA DVI LED Monitor
Quicklinx: 9DH8WS00 Mfr#: BDL:K1471V140-UK
The B19-7 LED offers best ergonomics and usability for intensive office use with a 4-in-1 stand.
Convenient and fatigue-proof longtime-usage with excellent visual ergonomics for the office ensured by wide viewing angle technology. Optimized and relaxed position - with ergonomic stand featuring height adjust, swivel, tilt and 90° rotation.
  • Exceeding ergonomics
  • Energy efficiency
    Environment-friendly LED technology with unique, high efficient energy saving solutions like ECO operation mode and ECO standby.
  • Manageability
    Ready for remote inventory and administration tasks due to the DisplayView Manageability tools.
Fujitsu B19-7 LED - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Marble grey
41.4 cm x 20.9 cm x 37 cm
5.48 kg
United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, BSMI, cUL, EN 60950, SASO, TUV S, VESA FPMPMI, CCC, DDC/CI, RoHS, ISO 9241-307, WEEE, KC, Directive 2004/108/EEC, EAC
Display Type
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Video Bandwidth
165 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, phase, clock, black level
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
sRGB colour management, HDCP, Eco-Mode, ECO button, DisplayView, WideView, High Frame Rate Control (Hi-FRC)
Marble grey
41.4 cm x 20.9 cm x 37 cm - with stand
5.48 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
Power Supply
Internal
14.6 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 41.4 cm - depth: 20.9 cm - height: 37 cm - weight: 5.48 kg , Without stand - width: 41.4 cm - depth: 6.4 cm - height: 34.9 cm - weight: 2.85 kg
TCO Certified
ENERGY STAR Certified
5 °C
35 °C
