- Fujitsu - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Dual rank, unbuffered
- Voltage
- 1.2 V
- OEM Manufacturer Equivalent Part Number
- Fujitsu S26361-F3909-L515
- Designed For
- PRIMERGY RX1330 M2, TX1320 M2, TX1330 M2
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- ECC
- Chips Organization
- X8
- Voltage
- 1.2 V
- Designed For
- Fujitsu PRIMERGY RX1330 M2, TX1320 M2, TX1330 M2
